Hub: w/ABS to car without ABS.
Old Mar 3, 2020 | 05:38 PM
Blue_SS's Avatar
Geg, I will bet money you can figure this out after seeing the picture.
Old Mar 4, 2020 | 12:02 AM
geg's Avatar
geg
Something like that I assumed.
It is unlikely that this sensor is attached to the hub deadly tight.
By the way, the supplier threw me a product photo. Very similar to what OldBlue posted earlier.
The brand is Korean, quality. Factory Supplier of Hyundai, Kia and something else Korean, including Korean GM.
But the most important thing - its already in Russia.
There is a spoonful of sh*t in this honey barrel: there are a lot of Chinese fakes due to the high quality of the brand. According to some reports, in Eastern Europe there are more fakes than original parts. Therefore, I will be careful and do not pay a cent until I consider the spare part very carefully.
Old Mar 10, 2020 | 06:31 AM
geg's Avatar
geg
Well, I bought it.
2 pieces, it seems like this is not a fake.
I carefully examined the ring with the ABS sensor, but at the first examination I did not find a way to remove this carefully.
Blue_SS - Perhaps you will tell the technology? You already did it.
Of course, I do not need sensors. But it’s a pity to spoil the thing. In addition, I can offer this to other owners of the HHR, spare parts are in short supply with us.
Old Mar 10, 2020 | 07:29 AM
I wouldn’t remove the plastic ring
Old Mar 10, 2020 | 11:32 AM
geg's Avatar
geg
On closer inspection, this is a metal upper casing containing a plastic component inside.
I tried to take it with a screwdriver and lift it up, but the gap is too narrow and nothing to lean on.
Perhaps the guys from the workshop know how to remove the sensors. I "ll ask.
Old Mar 10, 2020 | 12:14 PM
It’s really not necessary to remove it.
Old Mar 10, 2020 | 05:20 PM
Blue_SS's Avatar
Mine were OEM, but it just slides over that part on the hub. I used a screwdriver, and maybe a knife to start it. It's no longer fresh in memory. It's not difficult.
Old Mar 11, 2020 | 01:18 AM
geg's Avatar
geg
If it doesn’t work out, I will leave it in its regular place.
But first, I’ll try to dismantle it all the same.
Maybe I’ll clamp the hub in a vice and start wielding with a hammer.
In my penultimate photo, I saw a characteristic concave track along the lower circumference of the ring. I think the ring is crimped around the hub, so it holds tight.
In general, I decided:
if i can remove without damage - good;
if it doesn’t work out - also not a problem.
Old Mar 11, 2020 | 05:51 PM
Blue_SS's Avatar
hammer is a bad idea. But, I think you will succeed, in one way or another.
Old Mar 17, 2020 | 02:45 AM
geg's Avatar
geg
..., happy end.
1. Hub ILJIN # ij123046 suitable for HHR 2.4 2006 AT w/o ABS;
2. The ABS sensor does not interfere, but clutters the space + serves as a dirt collector. I got rid of it with a wooden hammer and a "damn mother". The sensor is not damaged or even scratched;
3. Mileage 200 km, no problem (for now).
PS
I looked to see if it is in the USA.
There is. But for some reason, these are Hispanic sites. I don’t know, maybe it’s local specifics.
Below is a diagram, maybe someone is interested in size.
mm in inch:
1 inch = 25.4 mm
the number of teeth on the shaft = 33 pcs
