Interior buzz/rattle fix: seat belts
Old Nov 30, 2018 | 03:01 PM
paulBvtn's Avatar
I think I finally fixed/reduced the noise that's been in my ear for 6 years: seatbelt mount noise.
I've tried multiple times to silence it.
I think I finally figured it out: Seatbelt mounting bolt to D-ring vibration.
Both of these parts are metal (no surprise, need strength for impact).
The seatbelt bolt has a metal doughnut spacer to allow the D-ring to rotate even when the bolt is correctly tightened. But this leaves a tiny bit of play and the two metal parts can vibrate together.
My current solution (other suggestions welcome!)
1. Remove cover & seatbelt mounting bolt (Torx + big wrench)
2. Remove lock washer that holds bolt inside seatbelt D-ring ( I got it started with tiny screwdriver and needle-nose, then could just thread it off the bolt)
3. bolt & spacer slides out of D-ring
4. Cut a "washer" of reasonable size from closed cell foam sheet (leftover from sound deadening project, e.g. https://www.sounddeadenershowdown.co...-cell-foam-ccf)
5. Washer can be oversized, since trim piece will cover it all.
6. reassemble with new washer between bolt head and D-ring
I'm hoping the closed cell foam will last a while, it's not designed for motion/friction so it may tear appart over time as the seatbelt moves.
But the thickness of it holds the D-ring and bolt quiet.
So far, I can't tell any rattle next to my ear.
Unfortunately it's taken me so long to fix that the rest of the car, particularly passenger side dash is rattling loudly. Arg.
oldracer
Dec 18, 2015 10:03 AM
chevyorange
Sep 19, 2009 03:05 AM
ccsubruce
May 6, 2008 06:27 AM
