Is my timing chain hanging right? Pictures
The tensioner extends with oil [edit -and also spring] pressure, but retraction is limited by a ratchet mechanism. These sometimes fail due to breaking, wear, sticking... I returned an aftermarket one that malfunctioned right out of the box. Ended up using OEM, night and day quality difference. GM has had issues with these over the years. I would only buy OEM, new stock, no Ebay bargains.
The tensioner extends with oil pressure, but retraction is limited by a ratchet mechanism. These sometimes fail due to breaking, wear, sticking... I returned an aftermarket one that malfunctioned right out of the box. Ended up using OEM, night and day quality difference. GM has had issues with these over the years. I would only buy OEM, new stock, no Ebay bargains.
oh wow! Yeah I was afraid to tinker with it before installing. Very intimidating work for the simpleton like myself
I think you’re referring to the balance shaft/water pump chain tensioner. The timing chain tensioner is spring loaded , you push down to release the plunger that applies pressure to the chain shoe, oil pressure takes over after start up.
The "old" mechanical version is better called the non-VVT version. All VVT versions are the "new" version and are hydraulic, the might have a helper spring but it is not the primary adjuster mechanism.
I expect pulpfriction will produce his pictures of disassembled tensioners.
