Is my timing chain hanging right? Pictures
Old Aug 15, 2025 | 07:19 AM
TurboKid1994's Avatar
Originally Posted by Oldblue
What brand chain kit did you first install?
this was the large MELLING vvt combo kit.
Old Aug 15, 2025 | 08:07 AM
Good to note, contact your point of purchase and advise them of the failed part.
Old Aug 15, 2025 | 08:39 AM
I don't know how a tensioner could "fail". It is hydraulic. They fully extend when the chain stretches too far.
Old Aug 15, 2025 | 11:03 AM
Internal spring may be weak or broken.
Old Aug 16, 2025 | 08:32 PM
PulpFriction's Avatar
The tensioner extends with oil [edit -and also spring] pressure, but retraction is limited by a ratchet mechanism. These sometimes fail due to breaking, wear, sticking... I returned an aftermarket one that malfunctioned right out of the box. Ended up using OEM, night and day quality difference. GM has had issues with these over the years. I would only buy OEM, new stock, no Ebay bargains.
Old Aug 16, 2025 | 09:47 PM
Well gents that’s the second time my hhr cheated certain death! Purring like a kitten now. Thx for the input.
Old Aug 16, 2025 | 09:48 PM
The tensioner extends with oil pressure, but retraction is limited by a ratchet mechanism. These sometimes fail due to breaking, wear, sticking... I returned an aftermarket one that malfunctioned right out of the box. Ended up using OEM, night and day quality difference. GM has had issues with these over the years. I would only buy OEM, new stock, no Ebay bargains.
oh wow! Yeah I was afraid to tinker with it before installing. Very intimidating work for the simpleton like myself
Old Aug 17, 2025 | 07:13 AM
I think you’re referring to the balance shaft/water pump chain tensioner. The timing chain tensioner is spring loaded , you push down to release the plunger that applies pressure to the chain shoe, oil pressure takes over after start up.
Old Aug 17, 2025 | 07:35 AM
A video explaining how the tensioners work
Old Aug 17, 2025 | 08:45 AM
The "old" mechanical version is better called the non-VVT version. All VVT versions are the "new" version and are hydraulic, the might have a helper spring but it is not the primary adjuster mechanism.
I expect pulpfriction will produce his pictures of disassembled tensioners.
