Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Oil Change Q... (https://www.chevyhhr.net/forums/maintenance-upkeep-50/oil-change-q-1935/)
SCOOT May 9, 2006 07:29 AM
Oil Change Q...
Well... went to work today and forgot my manual- no way to reference 'factory recommendations' for an oil change I'd like to do tonight (want to buy oil/filter on the way home).
So- if anyone can lend a hand, it'd be appreciated.
Now I know "OIL" and "FILTER QUALITY" is a touchy subject for some - that's not what this post is about...
I gathered the following from other posts:
- Fram filter P/N: CH9018
- Napa filter P/N: FIL7082
- 1 1/4" (or 32mm socket) for cannister lid
- 15mm bolt for drain plug
My question is 'What GRADE oil does the manual recommend as replacement?' Also- What does the manual say about 'quantity'? I have a feeling the manuf suggests upwards of 4-5 quarts of 5w-30 but am looking to verify.
As for me, I plan on running Castrol's SYNTEC, however, have never used anything besides 'fossil juice' in the past. Anything I need to know/consider before switching over (besides not switching back to conventional)?
Also- I've ALWAYS run 10w-30 in my vehicles... for no particular reason at all. If they differ, should I stick with manuf suggestions??? Lastly- what weight are you guys running (and why)?
:thumb:
four61ob May 9, 2006 08:13 AM
I use NAPA filters and oil, it takes 5 quarts of 5w-30, why...it says so ! also I change my oil every 3k no matter what anyone says....and always before and after long road trips (1500 miles+)....I just do, don't know why
cj krause May 9, 2006 08:24 AM
Wix is a much better filter for all around and you need to read about the DIC and how much chevy spent researching it and the oil life.
read what Chevy says,,,they warranty your engine
four61ob May 9, 2006 08:42 AM
cj, where can I read this....but I really like changing my oil every 3k, I rotate the tires, drink a beer, grease the fittings, drink a beer (oh, as far as I can tell there are no fittings to grease on the HHR, is this right, I replaced this step with drinking a beer btw) oh yeah drink a few beers....put away all my stuff for oil changes and tire rotating, clean my tools and drink a beer...if I follow what GM says, then it will look like I have a drinking problem !
SCOOT May 9, 2006 08:59 AM
My plans exactly... 3400 miles to date and want to get the original crap outta there - regardless of what my DIC says!!! (:lol:)
Just forgot to bring the book with me to read at lunch... would hate to start drinking - just to have to run to the local auto parts store!!!
Thanks again for the responses :D
cj krause May 9, 2006 09:06 AM
first oil change i did sooner, lil over 1000 miles
after that the DIC is what i have used and royal purple going in at 15,000 miles
going to get royal purple put in tranny too
Tokyo May 9, 2006 09:46 AM
Not sure this link will work if you're not logged in, but...
https://www.mygmlink.com/pdf/go2cont...et/2006hhr.pdf
It's the owners manual, in it's entirety from GM Link.
5qt for engine oil, BTW
Navyflyer11 May 9, 2006 10:55 AM
cj, ...if I follow what GM says, then it will look like I have a drinking problem !
If you follow what GM says the only drinking problem you will have is not drinking as often.:lol:
SCOOT May 9, 2006 11:18 AM
:bow: You ROCK Tokyo!!! :bow:
The link works...
courthousedeb May 9, 2006 11:26 AM
Think maybe this link should be a sticky somewhere so it doesn't get lost in the shuffle. Good find Tokyo!!! :thumb: :one:
