Oil Change Q...
Old May 9, 2006 | 11:35 AM
Thumbs up
Thanks Tokyo.
Just added the link to my yahoo bookmarks.
Old Jul 9, 2006 | 09:09 PM
ssmail8835's Avatar
Originally Posted by cj krause
Wix is a much better filter for all around and you need to read about the DIC and how much chevy spent researching it and the oil life.
read what Chevy says,,,they warranty your engine
Sharp mods to your HHR, cj
Old Jul 9, 2006 | 11:40 PM
bigbear2k's Avatar
LOOK AT THIS (One year for an oil change)
Engine Oil Life System
When to Change Engine Oil
Your vehicle has a computer system that lets you know
when to change the engine oil and filter. This is based on
engine revolutions and engine temperature, and not on
mileage. Based on driving conditions, the mileage at
which an oil change will be indicated can vary
considerably. For the oil life system to work properly,
you must reset the system every time the oil is changed.
When the system has calculated that oil life has been
diminished, it will indicate that an oil change is
necessary. A CHANGE OIL SOON message in the
Driver Information Center (DIC) will come on. See
DIC Warnings and Messages on page 3-42. Change
your oil as soon as possible within the next 600 miles
(1 000 km). It is possible that, if you are driving
under the best conditions, the oil life system may not
indicate that an oil change is necessary for over a year
However, your engine oil and filter must be changed
at least once a year and at this time the system must be
reset. Your dealer has GM-trained service people who
will perform this work using genuine GM parts and reset
the system. It is also important to check your oil
regularly and keep it at the proper level.
If the system is ever reset accidentally, you must
change your oil at 3,000 miles (5 000 km) since your
last oil change. Remember to reset the oil life system
whenever the oil is changed.
Not that is just crazy talk.
I got that from the manual
https://www.mygmlink.com/pdf/go2cont...et/2006hhr.pdf
Old Jul 10, 2006 | 08:29 AM
EZ4U2CHere's Avatar
Actually I bet once a year isn't unreasonable for some people. Heck, I only put 6k miles on my truck the first 14 months I had it.
Old Jul 10, 2006 | 09:11 AM
cj krause's Avatar
thank you very much
Old Jul 13, 2006 | 07:11 PM
EZ4U2CHere's Avatar
Will I run into anything weird changing the oil? I'd like to get the factory stuff out of there around 1500 miles, and I'm getting close. Just wondering if Chevy pulled any tricks like needing special tools? I'm too lazy to go crawl around and look for myself. LOL
Old Jul 13, 2006 | 07:17 PM
SoCalHHR's Avatar
Those thin little half-glasses with the LED's on each side might be cool?
Old Jul 13, 2006 | 07:58 PM
EasyRay's Avatar
1 1/4 inch socket for filter
extension
Ratchet
15mm Box wrench for oil pan plug.
Change filter first.Oil drains into pan.
Drain Oil
Replace plug
Add 5 Quarts of 5W-30 of what ever Oil you like to use.
I didn't have to get under to drain it. Just a little reach.
Real Easy!
Old Jul 14, 2006 | 07:25 AM
SCOOT's Avatar
EZ... I agree with John. Although I paid (what I feel is) too much for a socket ($8 @ my local auto parts store) it made the job effortless. I must say- this was the first time I changed a filter *without* laying on my back! I've never experienced 'cartridge' style filters before -but- after dealing with it... I'd NEVER want to change a conventional filter again!!!
All-n-all... no problems- just bite the bullet and get the socket... it'll make life that much easier!
Old Jul 14, 2006 | 10:17 AM
cj krause's Avatar
$5 at Sears for a Craftsman 1.25 inch socket.
works great and lifetime guaranteed
solman98
Maintenance and Upkeep
255
Aug 8, 2014 07:39 AM
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
23
May 12, 2013 02:01 PM
SIHHR
Feb 14, 2007 07:35 PM
