Oil weight
Old Jan 18, 2018 | 05:54 PM
Cat Man HHR's Avatar
Oil weight
I saw this on a recent closed tread and would like to explain something about it.
"I switched oil to the New Rotella T6 5-40 full Syn. and so far the gas mileage is about 2 better than Rotella T 15-40 which is not Syn and thicker. The thinner oil could be part of the increase in mileage and the fact its full synthetic. "
Both the synthetic and conventional oil are the same weight of 40 at an operating temperature of 210* F. The 5w or 15w in front of it is the spec at which it can flow properly at a colder temperature as explained here:
Motor Oil Viscosity Grades Explained in Layman's Terms
Old Jan 18, 2018 | 06:20 PM
It is probably the heavier weight has the oil pump struggling to push the sludge around and the crankshaft meets the sludge. And the VVT can't work correctly.
06burntorange
Maintenance and Upkeep
25
Jan 16, 2021 09:07 PM
jcgc50
Sep 19, 2009 07:49 PM
catdaddy137
Apr 4, 2009 09:21 PM
wolfee
Jul 24, 2006 12:03 PM
ChiTownHHR
15
Jul 8, 2006 11:31 AM
