opening a sunroof without power
Old Sep 23, 2012 | 07:43 AM
jaytheredneck1's Avatar
Is there some kind of hidden manual crank for the sunroof? perhaps hidden by the headliner?
My wind deflector, like many many many others, has decided to break off at that infamous clip. And rather than buying an aftermarket deflector that will look out of place, I've decided to hunt a factory one at the wrecking yard tomorrow before work. But the problem of how will I open a sunroof on a dead car has entered my mind.
I don't even think I need the deflector, do I? Should I just grab the clip?
Old Sep 23, 2012 | 09:54 AM
IgottaWoody's Avatar
well...could wire in thru fuse to open the window,, use a portable jump start box...
or trash headliner and remove motor.......
Old Jul 9, 2014 | 02:24 PM
sbagdon's Avatar
Even if you energized the vehicle, wouldn't you still need the ignition key to energize that circuit. My vote would be a small 12v battery, pull the headliner, then hotwire the motor to move the glass.
Old Jul 9, 2014 | 07:24 PM
db/sb's Avatar
I'm surprised that the HHR doesn't have a manual crank setup for emergencies but I don't see it in the manual. Our HHR didn't have a sunroof but every vehicle I've ever owned had one had a manual system also. What are you supposed to do in the interim if there is a problem that leaves the sunroof open?
Old Jul 9, 2014 | 09:10 PM
Snoopy's Avatar
Don't have an answer for opening the sunroof without power.
BUT the repair kit is about $20 from the dealer (at least when I purchased mine the retail was about that).
Blue Beast (aka Boydie)
Jul 16, 2013 04:55 PM
dhansen871
Jun 12, 2011 09:30 PM
tracy waddell
South Pacific
10
Oct 24, 2010 09:21 PM
stelerz
Jul 18, 2010 12:17 PM
GDZHHR
7
Mar 23, 2008 12:18 PM
