P0420 code and engine in limp mode
Old Aug 5, 2024 | 06:13 AM
Thanks
Old Aug 5, 2024 | 01:02 PM
An overfull tank is worse than underfull; there is a "full" line it is hard to see. If there is too much the mass is too much for the pressure to overcome.
Old Aug 5, 2024 | 01:35 PM
Prowlrman's Avatar
Thanks. I looked in the owners manual and it showed that level mark. Yes it is hard to actually see but I set it at that level as you indicated.
Old Aug 9, 2024 | 06:32 PM
PulpFriction's Avatar
Wut? I don’t understand that. I think the opposite is true.
If the coolant recovery tank is too full, as the hot coolant expands in the system, the excess is ejected through the pressures cap and will simply overfill the tank and the excess will spill to the ground via the overflow tube. If it’s too low, the shrinking coolant could draw all the coolant from the tank and then start drawing air.
Holding your phone flashlight against the tank makes the coolant level easy to see.
Old Aug 9, 2024 | 11:05 PM
Blame my lying eyes.
Jasonw7684
Oct 1, 2022 02:47 PM
domenick_2010HHR
2.2L Performance Tech
10
Jan 25, 2018 01:41 PM
skltnjak
2.4L Performance Tech
13
Sep 29, 2014 05:31 PM
Johnhern777
Apr 21, 2014 05:26 PM
Geoff
Jan 21, 2010 05:23 AM
