Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Preferred Brand of Oil (https://www.chevyhhr.net/forums/maintenance-upkeep-50/preferred-brand-oil-41018/)
Tyler Harvey Jun 8, 2012 01:59 PM
Only use Mobil 1 Synthetic.
JoeR Jun 8, 2012 01:59 PM
Originally Posted by Catch 22 (Post 649532)
I use Mobil 1 or Quakerstate full synthetic 10w-30w with a NAPA Gold filter. I wouldn't use 5w anything in any engine that belongs to me. I change my oil/filter at 5000-6000 miles nomatter what the computer says
Thank you for your "opinion"! :clappy:
firemangeorge Jun 8, 2012 02:07 PM
What Kind of Engine Oil to Use
For Vehicles With the 2.2L or
2.4L L4 Engine
Look for three things:
• GM6094M
Use only an oil that meets GM Standard GM6094M.
• SAE 5W-30
SAE 5W-30 is best for the vehicle. These numbers on
an oil container show its viscosity, or thickness. Do
not use other viscosity oils such as SAE 20W-50.
• American Petroleum Institute (API) starburst symbol
Oils meeting these
requirements should have
the starburst symbol on
the container. This symbol
indicates that the oil
has been certified by the
American Petroleum
Institute (API).
Notice: Use only engine oil identified as meeting
GM Standard GM6094M and showing the American
Petroleum Institute Certified For Gasoline Engines
starburst symbol. Failure to use the recommended
oil can result in engine damage not covered by
the vehicle warranty.
(copied from the HHR owners manual)
roguewave Jun 26, 2012 01:50 PM
I've used regular ol castrol for many many years in all my 4 cylinder high revving engines. I drive the crap out of all my stuff and I have never had a engine failure or excessive oil burn.
I've owned a few full service gas stations over the years and worked on many cars. In my years of doing automotive work I can count the number of times on one hand cars that needed a engine overhaul, happens very little. The oil makes little difference IMHO. All the other parts wear long before an engine.....this should stir the pot :lol:
IgottaWoody Jun 27, 2012 12:47 AM
^ What he said.....eng metals and oil are a science now..not that much of a factor unless..your pushing the limits...in other vehicles the main reason for running syn oil was to cut oil changes..for the amount of miles I was accumulating I had better things to do then be under the front end all the time( and the fact alot of my time was in the race car). Cars are so maintenance free anymore you almost have to post reminders to check things. I have about 55k on the SS and still 80% away from the 4th oil change.....
hyperv6 Jun 28, 2012 05:45 AM
The major issue with many of todays engines are they are now running hotter, running Turbochargers in family sedans and they are using the oil in the engine to cool the pistons to run higher compressions. Also in many engines the oils are now used as a hydraulic feature to adjust VVT cams etc.
There is much more demand on oils today and will be more demanded in the future. The time is coming where near every factory engine will require a syn oil.
With oils it is not what you did over the last 20 years but what the MFG requires in the manual today. Much of this will be due to the wide spread use of Turbochargers and the use of oil cool pistons to run higher compressions. Engine oil temps today are higher than they ever have been.
roguewave Jun 29, 2012 07:49 AM
What you say is true in many aspects, I just feel people place waaaay to much emphasis on the correlation between oil type and engine longevity.
BTW, we have 3 turbo'ed cars. 2 1.8 GTI'S and a BMW 335i?
The BMW uses euorpean synthetic castrol and we use regular ol' castrol in the 2 GTI'S, both have 100K and use zero oil between changes.
hyperv6 Jun 29, 2012 04:25 PM
It was once true that you could use oil made out of piss and go 100,000 miles but that is becoming more and more a thing that will not apply to newer engines.
Like many things that once were true will no longer apply with future engines and vehicles.
jimfet Jul 3, 2012 06:56 AM
I use Mobil 1. Change my oil once a year. But I only put around 6K on my HHR a year. Every March, I get my car inspected, tires rotated and oil changed at the local chevy dealer. Now I'm good to go for another year.
