Question about coolant in lower hose
Old Jun 17, 2025 | 07:01 AM
PulpFriction's Avatar
Just for the good of the order, a wordier explanation-
When the car is hot, the coolant expands and the system pressure increases. When it exceeds 15-16 psi, or so, the pressure cap releases coolant to the recovery tank, thereby limiting the system pressure and preventing “unscheduled rapid release of coolant.” (Pressurizing the system has the desirable effect of raising the boiling point of the coolant.)
This pressure makes the hoses feel firm.
When the car is turned off, the engine stops making a waste heat, the coolant contracts, and the pressure drops. At some point during the cooling, the pressure goes slightly negative. The expelled coolant was routed to the bottom of the recovery tank. This is important. Now, atmospheric pressure can push the amount of coolant expelled into the recovery tank back into the circulating system. This function makes it also important that the coolant recovery route is leak-free all the way to the bottom of the tank.
Now we’re at 0 psi, and the hoses feel soft.
Rinse, lather, repeat.
Old Jun 17, 2025 | 09:38 AM
Great detail, I always just thought coolant was sucked back into system from recovery tank by vacuum..
Thank You Sir
Old Jun 17, 2025 | 03:53 PM
Pressure differential results in vacuum on the low side in a closed system
PulpFriction's explanation did not get into why it is important to not over fill the recovery tank, but it is implied. There is a full line on the bottle, it is hard to see.
Old Jun 18, 2025 | 09:56 AM
10-4 Thanks Don..
Old Jun 18, 2025 | 10:07 AM
You are correct, really. Except in physics class. In that world, basic instruction emphasizes that sucking really means higher pressure pushing stuff to a place of lower pressure. “Vacuum” is just absence of pressure, and can’t do anything unless there’s pressure somewhere else.
Originally Posted by donbrew
…PulpFriction's explanation did not get into why it is important to not over fill the recovery tank, but it is implied…
Good point! Overfilling if nothing else will, upon warmup, spill excess coolant to the ground.
Old Jun 18, 2025 | 10:31 AM
Thank You ALL
Bird Doo Head
Jan 31, 2025 07:47 PM
KenK
Apr 6, 2022 02:10 PM
shojay92
Aug 12, 2017 11:10 PM
Ron
Apr 4, 2011 11:57 AM
SnoopHHR
Maintenance and Upkeep
Jan 6, 2009 09:44 AM
