Welcome to the site :smile: did you have the drums turned? If so they may have cut them at the wrong speed.
I had that happen a few times. When the drum are cut too fast it make the cut like a record. As you apply the brakes the drum pulls the shoe away from the baking plate then the shoes snap back. Most of the time it's only one side that makes noise because the other side will push the shoes toward the baking plate. If this is your problem get them both redone. |
Originally Posted by Lucky
(Post 744872)
2 Attachment(s)
Originally Posted by donbrew
(Post 744824)
Those pics look suspiciously like the set of a "rehab" TV show? Attachment 23415 Attachment 23416 |
You seem to have more then enough experience dealing with this stuff. I just find that the HHR has a lot of weird little idiosyncrasies that have scratching my head.
I just did the rear drums on my wife's '06 LT. Had the drums turned and replaced all of the hardware with the change. I don't have the clunk but I had to back the adjusters out a lot more then I expected to get the rear brakes to do anything. Once that was done everything is good. Nice shop and ride's by the way. That Rod is sweet. |
