Replacing Headlight Bulbs
Old Feb 24, 2011 | 09:24 AM
  #31
malibuhhr's Avatar
new to this, I have to use "IMG code", not "HTML code".
lets try this again:
[IMG][/IMG]
and under the bumper:
[IMG][/IMG]
Old Feb 24, 2011 | 09:30 AM
  #32
speedwagen's Avatar
I did mine last night after reading this thread.
metric socket, clip removal fork, turned the wheel all the way out (didn't remove the wheel)...no big deal.
So fear not, hop in there and save some $$
Old Feb 24, 2011 | 09:36 AM
  #33
malibuhhr's Avatar
arrrrgh photobucket keeps crashing on me, here we go again:
I pulled fasteners all the way around the arch until I could pull down the inner fender:
[IMG][/IMG]
easy access to both bulbs and the fog light (if installed):
[IMG][/IMG]
In Canada there are two bulbs, the Sylvania $14 "H13" (below) and the Bosch $25 "9008". Does anyone know the average longevity on each?
[IMG][/IMG]
Old Feb 24, 2011 | 09:39 AM
  #34
malibuhhr's Avatar
I'm posting 2-3 images at a time because this is taking all day:
to remove the bulb from the socket, DO NOT make this mistake:
[IMG][/IMG]
the socket requires some effort to remove and I could not ascertain if there is some clip or lock on it, but it eventually just popped off.
be careful not to touch the new bulb or your fingerprint will fry and the bulb will burn out within minutes:
[IMG][/IMG]
test the new bulb and check its aim against a wall:
[IMG][/IMG]
Old Feb 24, 2011 | 08:13 PM
  #35
Gas Man's Avatar
Good pics... but I had to cringe at the vise grip for removing the screws...
Old Feb 25, 2011 | 11:53 AM
  #36
malibuhhr's Avatar
vice grips work great on sheet metal screws! with needle nose pliers they slip off all the time and the screws end up on the floor...socket wrench is too slow, and with vice grip re-assembly is easier cuz you need to fish around a bit to align the holes, which is not easy unless you have a really tight grip on the screw.
Old Feb 25, 2011 | 01:12 PM
  #37
urbexHHR's Avatar
Nice pics! I was going to do a how-to when I changed my blinker bulb, but heck, I couldnt' fit the camera up in there!
Old Feb 25, 2011 | 08:29 PM
  #38
Gas Man's Avatar
The proper tool for the job. And I'm sorry vise grip isn't it.
Old Feb 26, 2011 | 04:16 PM
  #39
I am not sure if it's been mentioned here, but make sure you get the old gasket out before trying to put the new bulb in. The old gasket will try to stay behind and the new bulb has one already installed. The new bulb will not seat if there are 2 gaskets!
Old Apr 1, 2011 | 01:18 PM
  #40
jerSSey HHR's Avatar
My wife just texted me that the driver's side headlight is out. I figured it would be an easy replacement like all my other vehicles. Good thing I read up on this thread.
How GM could require this amount of work to change a stinkin' lightbulb is absolutely mind-boggling.
