If Seaforth is in Delaware, I would not be surprised that a car has rust problems. You have the double whammy of salt on the streets and salt in the air
Seaforth is also in Ontario Canada.....lots of salt on the road here too....lol
I'm going to trace the profile and record some dimensions to see about fabbing a new set. I could easily just patch the completely rotted area, but if I'm going to do it, I might as well do it right. The PITA part is the complete replacement which also includes stampings for drain areas. That's a lot of work unless I take some liberties with those areas.
Yep, it's fabrication time! I've cut out the worst areas finally.
As for the fab work being straight forward, it depends a little what area is affected. Mine, as I suspect others are, is the front portion, which includes some compound curves. I'll be doing a bit of cutting and shaping to replace all of the bad areas.
Luckily, since this will be hidden from view with the SS trim cover, it just needs to be structurally sound and keep the original mounting holes for trim and brackets.
Just an FYI, as I saw some other questions a while ago about body repair panels, there actually are a number of what GM refers to as service panels. These are individual sections of panels and supporting structures to allow for easier fitting and welding in of patches.
As for drain holes, the original panels do have drain holes from the factory, but these are not sufficient in some climates/circumstances. One of the things I plan to do is thoroughly coat these areas inside and out with FluidFilm to hopefully prevent further rusting (as reasonable as possible). Actually, I may move up to the WoolWax product for the exterior (under the car).
Hooray for salted roads :)
As found (with front bracket already removed). After cutting out the initial rot.
