strange issues after battery change, HELP!
As a matter of fact yes I did. It was a defective battery , one cell would not charge, there were enough volts and amps to start it but similar things did not work.
Is the new battery the correct amperage for the HHR? Was it fully charged?
Question,
Did you follow the correct procedure to remove and replace the battery in an HHR??
1. Remove Plastic panel to make room.
2. remove spare tire.
3. Remove negative battery cable.
4. Remove very carefully the battery vent tube.
5. Remove the positive battery cable.
6. Remove the hold down clamps.
Reverse all above to re install.
SF
SF
not sure never tested it, bought at advance auto parts. sort of didn't have time to do all that stuff, sadly. had to be to work at 6pm and didn't have access to multimeter etc. i'll check everything and follow up.
checked fuses, including 50amp fuse by battery, everything is good there, fuses are ok. guess im going to call dealer on monday and see if they can get me in.
hopefully it won't be too complicated. UGH!
fuse is great, pulled it and everything cut off. re seated fuse, checked connections car started.
nope same symptoms, no radio, keyless entry etc. don't really have any more time to troubleshoot it. im thinking like you are something somewhere with the BCM fuses, however they look good, not blown? if part of computer is fried, i don't know what im going to do.
haven't swapped fuses yet. really have run out of time (due to work) to troubleshoot on my own.
all dash warning lights illuminate when i start car, Check engine light doesn't stay on. that's what makes me think its either a fuse or a short somewhere.
the bigger maxi fuses in engine compartment are tight and very hard to pull im afraid ill damage them by pulling them out. the 50 amp max fuse by battery was good. and all the other fuses i checked (visually) appeared fine. i pushed each fuse/relay down to ensure they were making good connections. i'm really hoping its just a fuse.
