VVT solenoid replacement- brand recommended ?
Old Aug 21, 2024 | 07:40 PM
unknwn's Avatar
2010 2.2 w/138,000 miles - No codes-no symptoms.
If you were to replace these -often problematic(?)- parts due to aging & accumulated mileage, what parts would you be buying to insure against mystery failures?
When I replaced -like- parts on a V6 Lexus, I opted for the NTK brand which is an NGK (genuine Japanese) automobile hard parts source.
These are components that I'd -NEVER- opt for least expensive/house brand variety, so I'm inquiring regarding experience -or - lack of problematic experiences.
Old Aug 21, 2024 | 08:47 PM
When they fail it is not catastrophic. Wait for a code to worry about them P0010, P0011, P0013, P0014. Replace both when you do.
P0016 & P0017 mean the timing chain is the problem, not the sensor.
Old Aug 21, 2024 | 08:48 PM
greg8453's Avatar
If it's running ok and not coding we don't bother with them. Not a maintenance item. When they need replacing use OEM.
Old Aug 21, 2024 | 08:49 PM
unknwn's Avatar
I found this product brochure by the Standard Motor Products, touting their 'Blue Streak' line of VVT parts.
The product line is manufactured in Poland.
When investigating replacement coil-over-plug parts for my Lexus, NAPA markets 'premium' components that are likewise manufactured in Poland.
The Gates products inform that they are covered by a 'limited lifetime' manufacturer warranty, but those parts originate in China.
https://www.standardbrand.com/media/...gle-page_a.pdf
Brochure indicates 'Lifetime' warranty, but R.A insists that 'only' 36 months applies.
Old Aug 21, 2024 | 08:57 PM
Standard Motor Products is a crap brand.
Old Aug 21, 2024 | 09:04 PM
unknwn's Avatar
Delving further into the Standard Motor Products Blue Streak VVT pages, these solenoids are a suggested 'cure' for intermittent start up rattle on GM 2.4 series engines.
Sure is a mighty fine screen over the ports on these things, and if they could be susceptible to 'leak-down', could this be a valid reason behind that pernicious noise emanation?
Old Aug 21, 2024 | 09:07 PM
unknwn's Avatar
Haven't gotten around to pulling the solenoids and inspecting for any 'trash' bound up on those screens yet.
What are other's experiences of such?
Old Aug 21, 2024 | 09:14 PM
unknwn's Avatar
At least the Genuine GM replacement parts 'says' that it originates in the United States.
Amazon Amazon
And yeah, I'm aware that the GM/AC-Delco parts can be sourced less expensively else where.
Old Aug 21, 2024 | 10:21 PM
Bonez's Avatar
ACDelco is the only way to go with the VVT
Old Aug 22, 2024 | 06:50 AM
^^^^ What he said!!
