A What are they called ?
Old Mar 6, 2022 | 03:34 PM
Radco's Avatar
I am talking about the little plastic cover in the door grab handle that covers the 2 screws. I got 1 as a template but the material is too soft and does not fit as good as I would like,
Yes you can not see them well but I know they are a fair fit lol
Any idea where to get 4 ?
No HHR in the pick and pull yard !
I looked on line but all I find is the replacement door handle !!
THANKS
Old Mar 6, 2022 | 04:01 PM
Liner.
Part Number: 15146915
Fits HHR (2006 - 2008)
w/o SS model.
It is 113.7 mm, looks like it's for LH side.
LINER. Front Door Trim. Rear Side Door Trim Finish.
Part Number: 15146916
Supersession(s): 25874249
LINER,RR S/D PULL CUP(131.2MM)(W/TAB)(14.691). LINER,FRT S/D PULL CUP(131.2MM)(W/TAB) - RH.
Part Number: 20898014
Fits HHR (2008 - 2011)
LINER,FRT S/D PULL CUP(EBONY)(110.5MM)(FLAT LINER)(14.764). LINER,RR S/D PULL CUP(EBONY)(110.5MM)(FLAT LINER)
Old Mar 6, 2022 | 04:20 PM
I cut a set from a vinyl splash shield I had in the shed. The BlackSwan only had one when I bought it, the earlier 2007 from Oldblue were different.
Old Mar 6, 2022 | 04:40 PM
Radco's Avatar
I had a Black lid to a coffee can laying around. SO trying that !. I cut a old mouse pad to fit but as light and loose as it fit it will fall out ! So with a bit more trimming I think the plastic lid will pop in.
Getting dark out so will play again tomorrow lol Thanks
Old Mar 6, 2022 | 05:52 PM
Many years ago I put double sided tape on the back of my liners. Haven't lost one yet.
I think a lot of owners lost their liners via a vacuum cleaner.
Old Mar 6, 2022 | 08:51 PM
Radco's Avatar
More then likely your right ! I do not know if mine were ever there. But I like the idea of the double sided tape :) When I get mine fitted that is what I'll do
Old Mar 7, 2022 | 04:04 PM
Radco's Avatar
Good tip about the tape George
I made a set out of a Old Gateway Foam mouse pad, Pealed theplastic logo off and it was still sticky so no tape needed :)
And the pad was heavier then the coffee can lid so harder to blow out !
Thanks for the tip everyone
Old Mar 9, 2022 | 04:12 PM
They usually can be found in the bottom of the vacuum cleaner dust bin.
Old Mar 9, 2022 | 04:55 PM
Maybe so Don. But what about the folks that use the commercial vacuums at their local car wash place. Not sure they would appreciate folks digging into those dust bins.
Old Mar 10, 2022 | 08:24 PM
PulpFriction's Avatar
LOL. Can confirm. Pulled them out of my shop vac once or twice.
