Window not working
Old Feb 27, 2022 | 02:39 PM
I don't trust the information in that link. The online owner manuals disagree in 2009 thru 2011. I think that layout is only good thru 2008. In 2009, things changed.
I reviewed that and think your right, the 2009 and up have different harness like the 2008 to 2010 SS . The internet, who knew , it can be wrong.
Old Feb 27, 2022 | 06:04 PM
Radco's Avatar
Pulpfriction he did retry the old master swwitch
Checked the manual and the fuse location looks right !
I read somewhere that the BCM may have to reflased :O Found some articals on that .. So will see
Old Feb 27, 2022 | 09:08 PM
The is that it is a simple jumped the track problem originally. I don't know what wire might have been broken now.
if it is making a sound that means the switch is working and the motor is trying.
Old Feb 28, 2022 | 05:48 AM
Radco's Avatar
Don I agree if it was only 1 window but it is all 4 :O
I am throwing in the towel . He is calling his mechanic today and if it is something they can not do off to the dealer !
Have you ever heard of the HHR needing a Reflash ?
To fis issues ?
Thank You everyone. Will update what we finally find out
Old Feb 28, 2022 | 06:23 AM
Windows aren’t computer controlled, so the BCM won’t need a reflash.
it’s most likely a broken wire, pins bent in the connector.
Old Feb 28, 2022 | 07:38 AM
  #26
The "Master" switch feeds the other switched. When it was changed most likely a wire/connector was compromised. Like maybe the Master lock.
Old Feb 28, 2022 | 09:07 AM
  #27
Radco's Avatar
The pins looked good , I did check them after I put the Master Switch in,
But I could have missed something. Had same issue after trying the old master switch as well.
I told him to try and park in the sun at work today, Then try the windows in case any were froze shut !
He said he did hear a click of sorts when he hits the switch.
But even before the change of the Master Switch could not close passenger side rear window !
It goes to the garage tomorrow so his mechanic will check it out !
Steve I was wonder about the BCM and what it would have to do with the windows myself. Someone mentioned it on the FB HHR forum so had to ask !
Found some info on a google search and it did say a BCM may cause issues . But then again if it was from the web it has to be true lol
SO hopefully they can at least close that window.
So I should have some sort of update tomorrow and if it gets solved hopefully good info for someone else if ever needed
Old Feb 28, 2022 | 11:33 AM
  #28
On FB all problems can be fixed by replacing or flashing a computer. My advice is to discard everything they say.
Old Feb 28, 2022 | 12:26 PM
  #29
That’s why I don’t do Facebook. Besides they called us grumpy old men , no patience, and other stuff! lol
Old Feb 28, 2022 | 06:59 PM
  #30
Radco's Avatar
I agree,
I do not trust FB post 100% either !
I did google the question and found a few talking about issue caused by the computer and window issue were there as well.. so who knows.
Some say windows can be effected some say no :O SO now I am more confused d lol
Will know more tomorrow maybe
