Windshield leaks from top on one side
Old Jun 17, 2023 | 12:12 PM
dbena's Avatar
When I investigated, the black rubbery weather stripping (sorry if not technically correct) looks like it is well-placed on the side that does not leak, but worn and not filling the gap on the side that leaks. Two questions: (1) does anyone know if a replacement is available (and what to search for), and (2) is it as easy as carefully pressing it into the gap along the windshield perimeter?
Thanks a ton! Getting my wife's "baby" back in shape...slowly!
Old Jun 17, 2023 | 02:22 PM
Number 1 or number 3
https://www.wholesalegmpartsonline.c...ey_model=14513
Old Jun 17, 2023 | 02:39 PM
dbena's Avatar
Thanks so much!
Old Jun 17, 2023 | 03:20 PM
The black plastic molding (2 &3) is ornamental it can only be installed when the glass is replaced The windshield is sealed with RTV. There is no weather strip.
A new windshield is installed by applying RTV around the opening then pressing the glass in. I have had the glass replaced several times, many times the plastic bits get "lost".
Old Jun 17, 2023 | 06:05 PM
#1 is the Windshield. And what donbrew said, #3 is plastic and does not seal anything. The Windshield typically does not survive the removal process, so count on buying a new Windshield.
But are you sure it's the Windshield leaking? Other potential leaks are the antenna, and (since yours is 2006) the butyl patch under the cowl.
Old Jun 17, 2023 | 06:08 PM
Links in this thread
https://www.chevyhhr.net/forums/main...er-leak-56959/
Old Jun 17, 2023 | 08:14 PM
I edited mine. Cataract surgery in August.
ncampbell21
Oct 24, 2015 01:12 PM
daddy2isaiah04
Dec 3, 2011 01:28 PM
berky1976
May 3, 2011 02:54 PM
LawDog88
Feb 5, 2011 08:25 AM
kornellred
Oct 27, 2007 08:25 AM
