Mods - Engine/Exhaust EngineCompartment/Exhaust Discussions. (Non-Performace)
2.4 Exhaust on 2.2?
Old Jun 22, 2021 | 11:40 AM
tr34's Avatar
2.4 Exhaust on 2.2?
Hi, so my current muffler has an exhaust leak at the bottom of it, so I've decided to try and look for an upgrade possibly on the exhaust. I'm trying to decide between buying the walker 2.4 exhaust kit or the magnaflow muffler because they are around the same price. I'm wondering if installing a walker 2.4 catback stock replacement on my 2008 2.2 would make any difference in sound/air flow. The 2.4 exhaust is 2.25 inches in diameter, and they seem to be able to fit. I think oldblue did something similar to this before. I'm not sure which is a better bang for the buck
Old Jun 22, 2021 | 01:59 PM
Yes sir, I sure did! I started at the manifold, changed the down pipe from the weak skinny 2.2 1 3/4 pipe to a full 2” pipe mandrel bent so no kinks! The the Walker cat back, it didn’t make more noise but it did allow the 2.2 to breathe a bit better and picked up a mpg or 2!
the longer resonator was much better at stopping the ricey rumble.
Old Jun 23, 2021 | 09:41 AM
tr34's Avatar
Oh okay, thanks for the info, that helps a lot!
Old Jun 23, 2021 | 11:21 AM
Watch out at the middle flange gasket, don’t over tighten those bolts the flange can flex and damage the gasket causing an exhaust leak.
Old Jul 10, 2021 | 10:15 AM
tr34's Avatar
Okay, it's been a while but just following up on this, I got the walker 2.4 exhaust and left the stock downpipe for now (I'm thinking about replacing it with a ZZP downpipe if it ever does break), but the exhaust went on pretty easily. I left the muffler off for two days and it wasn't that bad of a sound, it was interesting that you can hear burble/pops when in I gear without the muffler. I have the muffler on now and it sounds just like stock, I don't see any improvements in MPG yet but I haven't really driven it that much yet.
Old Jul 10, 2021 | 10:18 AM
The stock down pipe on the 2.2 is very restrictive!
Old Jul 10, 2021 | 10:37 AM
tr34's Avatar
Yep, I noticed that with the 2 cats it has. I'm just trying to get the most out of the stock downpipe for now, but I'll eventually switch it over. It looks like 2 inch piping so there might be a slight but minimal improvement from me switching the resonator from 1 3/4 to 2 1/4
Old Jul 10, 2021 | 09:00 PM
Lonwane's Avatar
As the exhaust flows downstream it cannot reduce the back pressure cause by the 1 3/4" downplpe.
Air flow will always be restricted by the smallest diameter pipe and cannot increase flow rate.
Thus the reccomdendation to change it out to the bigger 2" version.
Old Jul 11, 2021 | 07:04 AM
Plus the 2” pipe is mandrel bent so no kinks in the bends, smooth flow , no turbulence.
Old Jul 22, 2021 | 04:35 AM
PulpFriction's Avatar
On a 2008 2.2 on a budget program to fix a leak or two I used a Walker 2.4 pipe/resonator with no change to the (highly restrictive) downpipe or muffler. I liked the sound better and my highly unreliable seat dyno sensed an improvement in response and power at higher rpm’s.
skyline26
16
Dec 2, 2014 09:12 PM
Joepoppa1
0
Nov 22, 2011 02:23 PM
hhr_2009
2.2L Performance Tech
Feb 3, 2011 10:55 AM
hhr_2009
Nov 15, 2009 07:50 AM
thompy53
Apr 3, 2006 10:03 AM
