best choice of engine swap for 2006 HHR
2006 2.4 is an odd 1 year only engine with the ignition pack on the valve cover , VVT and an external oil cooler, hard to find but they are out there.
https://www.ebay.ca/itm/165742590405...mis&media=COPY
There’s one^^^
There’s one^^^
There’s one^^^
There’s one^^^
The OP is 85 and just needs to replace his engine.
And Donbrew is right the 2006 LE5 2.4 l engine isn’t specifically just in the 2006 model year!
for fitment any year LE5 will do.
https://www.karlkustoms.com/product/...-engine-reman/
https://www.jasperengines.com/blog/j...tec-ohc-engine
https://paceperformance.com/i-513499...er-engine.html
The oil cooler is the big difference, they decided it wasn't needed on later models. So, a later model without it will work. 2006-2008 are LE5, the flex fuel 2009-2011 are LE9 not compatible with the ECM.
