Mods - Engine/Exhaust EngineCompartment/Exhaust Discussions. (Non-Performace)
Painted my fusebox
Old May 30, 2011 | 05:33 PM
jimpennjr's Avatar
Painted my fusebox
I used the Dupli-Color Mystify?. Had a kit laying around, thought I would give it a whirl. Didn't know how it would turn out so I only did the fuse box lid and the cover in front of the fuse box. I have another kit, probably will do the Air filter housing. Let me know what you think and if I should do the air filter housing.
Old May 30, 2011 | 05:48 PM
Zagohhr's Avatar
Old May 30, 2011 | 11:39 PM
Yea, paint the A/F housing to match...
Old May 30, 2011 | 11:43 PM
Love the color change effect!
Old May 30, 2011 | 11:53 PM
LewiSS's Avatar
Did it take a whole kit just to do those two pieces? How easy did it go on? I've been considering using that for some bike parts.
Old May 31, 2011 | 06:00 AM
jimpennjr's Avatar
LewiSS- I used the small can kit (Base, Mid, Clear). Since the pieces were black I didn't need a lot of the base coat. I did however use all of the mid color, Duplicolor states that the more coats, the better the effect. I did not use all of the clear either. It went on very easy. You only have to wait until tacky between coats and 30 minutes between steps (base to mid and mid to clear) If you are going to use it on bikes (motorcycles) it is not resistant to gas. Good luck and post your pics when done. I have another kit and plan on doing the air filter housing when I get more time.
Old May 31, 2011 | 10:14 AM
asanti's Avatar
I like it!
Later
Allex
Old May 31, 2011 | 11:02 AM
nacademus's Avatar
Fancy fancy! I like it! Clear it with a good amount of plastic paint clear. DO THE AF COVER lol
Old May 31, 2011 | 07:15 PM
jeff schaffer's Avatar
my last car was chamillion painted used that stuff inside my rear headlights looks great and changes colors with the sunlight.
jeff
Old May 31, 2011 | 08:21 PM
IndianaJ.J.'s Avatar
Thumbs up Painted Fuse Box
Go for it! I think it looks great! I especially like the color shift. Maybe I'll do something like that. Keep up the good stuff.
