2010 HHR convert to SS front fascia
Old 03-10-2011, 11:09 AM
Nic69's Avatar
Since my wifes was a case of hit and run in the parking lot and now it needs a front fascia. How hard would it be to put on the SS front fascia instead of the stock base fascia??
Any input would be great!
Thanks
Nic
Nic69 is offline
Old 03-10-2011, 11:13 AM
gcsd3742's Avatar
use the Search button.....It's not the same as the regular HHR... its wider if i remember correctly...there's a few posts on here about it
gcsd3742 is offline
Old 03-10-2011, 11:21 AM
Nic69's Avatar
You mean if I got an entire SS fascia it will not fit or match up to the hood and fenders?
Nic69 is offline
Old 03-10-2011, 11:25 AM
gcsd3742's Avatar
I believe you need the fenders hood and bumper...
gcsd3742 is offline
Old 03-10-2011, 11:28 AM
KINGSHIPLEY's Avatar
you need the facia and grille only if im correct but an ss on a non ss wont look right in my opinion. its a non ss body for a reason
KINGSHIPLEY is offline
Old 03-10-2011, 11:29 AM
You can use just the SS bumper but the Stock Grille will look short. You cannot just do the SS Grille without either modifying the Stock bumper or going with an SS bumper. If you plan on doing both SS grille and bumper then you are fine.
HillsdaleHHR is offline
Old 03-10-2011, 11:32 AM
HHR_SS_QC's Avatar
My sister has a 2006LT that she converted to an SS look alike.
You need the SS grille, the SS bumper fascia with the SS fog lights (which are different than the LT fog lights), and the foam absorber. The hood and fenders are the same.
HHR_SS_QC is offline
Old 03-10-2011, 12:44 PM
Nic69's Avatar
I was planning to change the grille as well to match, but not right away. I may have to give this a try.
Nic69 is offline
Old 03-10-2011, 03:18 PM
geesh's Avatar
I would love to see the pics and possibly a step by step how-to if you are up to it!! I love the look of the SS but couldnt see putting down 8-10 thous more for a work vehicle.
geesh is offline
Old 03-10-2011, 04:51 PM
Talvanos's Avatar
Actually there are a lot of little things that are different between the two. Rear of the grill they are the same, so no need for new fenders. The mounting brackets are different, and I believe the bumper absorber is different as well. Also, the fog lights are different and will require different pig tails for the new light bulbs. I almost did the swap myself when i T-boned a F-250. I stopped reseraching when i got to $500 additional cost because of price difference in parts.
Talvanos is offline
Quick Reply: 2010 HHR convert to SS front fascia
