ABS cement for 3 bar grille gap filling?
Old May 25, 2012 | 04:24 PM
Rod Run's Avatar
Originally Posted by Putter
The one pictured above is a stock grill with the extra bars removed. Then the sides are filled in with fiberglass to cover where the removal left small notches. Then finished, and painted.
The mesh that I used (can't say for certain what Rod Run used) is gutter-guard mesh found in the rain gutter section of Home Depot....then painted black.
That's pretty much what I did, except I didn't use the rain gutter stuff. It was actually from a sheet of diamond mesh that I bought and cut out. I have used this type in the past, along with different honeycomb ones also. All depends on the application. I'm thinking about buying a heavier mesh though, with a thicker screen so it's not as open
Greylotus11
Jun 22, 2013 11:20 AM
ouhockeyplayer
Jun 24, 2009 02:49 PM
ccsubruce
Tires & Wheels
20
Jun 17, 2008 11:06 PM
Ern
12
May 17, 2007 01:45 PM
Lee3333
Jan 18, 2006 09:39 PM
