Can paint stick to...........
Old May 11, 2008 | 12:00 PM
tooter1's Avatar
the satin chrome grille? I'm getting ready to paint one and need assistance on this topic.
Scuff, Primer, then Paint? Any info will be helpful.
Old May 11, 2008 | 01:07 PM
Old Ray's Avatar
There is very permanent product that is a primer that has an acid in it that etches into any metal and really sticks as a base for paint. I have used it on chrome grilles. Marketed under various names, vinyl wash primer is one, made by DuPont and Martian Senour (spelling).
Old May 11, 2008 | 01:47 PM
oneton's Avatar
Thats all good for metal I think that the grill is plastic !! don't know how a acid in it that etches will work?? IMHO
Old May 11, 2008 | 02:42 PM
catzcradle's Avatar
Uma has painted a chrome grille and beauty bar as well. May want to PM him or Sindy Dix. I believe you just sand it down, probably use a plastic adhesion promoter like Bulldog, then primer, paint, clear.
Old May 11, 2008 | 02:43 PM
dixiesHHR's Avatar
try scuffing, then self etching primer sold at all parts store then paint. Just make sure you degrease first and keep everything clean. Don,t get fingers on it after using the wax and grease remover.
Old Aug 19, 2008 | 07:41 PM
tamatt27's Avatar
Don't just paint over the grill as is. I did this, no bueno. It will last for a while...but it won't bond to the plastic.
Old Aug 19, 2008 | 08:21 PM
tooter1's Avatar
I scuffed the surface with 400 grit and used regular primer (I think). Mine has numerous layers of primer, paint, clear.
So far so good.
Old Aug 19, 2008 | 08:35 PM
saltyfishguy's Avatar
looks good, I got bored while stuck inside from the storm we had and cut my spare grille up also today. what paint did you use?
Old Aug 19, 2008 | 09:32 PM
tooter1's Avatar
I used this off ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...159314136&rd=1
A little expensive, but I couldn't find anyone in town that did this. Seems to be great paint.
Old Aug 19, 2008 | 09:34 PM
WaynesWorld's Avatar
Prep grille using a wax and grease remover. Sand grille with 400 grit. clean again with the wax and grease remover and tack it off with a tack rag. Use a plastic adhesion promoter then a primer sealer. Now you can use the base coat and clear. Let it flash for about 10 minutes between each coat.
I do this for a living
axxsys
Apr 11, 2012 08:28 AM
woodchuckd11
Maintenance and Upkeep
Mar 3, 2011 12:48 AM
mr.2lt
19
Oct 30, 2010 08:52 AM
bigjoe
Sep 27, 2009 10:03 PM
badbounder
Apr 22, 2008 10:34 PM
