Change to LED
I would like to change my headlights from standard to LED,is there a kit or bulbs to do the conversion?Thanks
moved to mods-exterior.
Our friends at Carid have these
https://www.carid.com/2010-chevy-hhr...204158250.html Or these https://www.carid.com/2010-chevy-hhr...204157925.html Then there's these from Oracle ORACLE H13 LED Headlight Replacement Bulbs - LED Headlight Bulbs - ORACLE LED Headlight - Fog & DRL Bulbs - ORACLE Automotive Lighting Products The choice of course is yours, all years and all models of HHR's have H13 headlight bulbs |
4 Attachment(s)
I did an LED conversion on my Elantra. Did quite a bit of research as most say there is no light output. Not sure how they work with reflectors, and especially a hi/low option. But I've very pleased with them. Personally, I'd avoid any with built in fans, as it seems the fan life is about half the LED life, but still longer than halogens. I'm using this style, rated at 5000 LM, 5500 kelvin. Plug and play.
Attachment 22322 I've since changed the LED in the fogs to match, cheap ones were too blue. Attachment 22323 Cut off line @ about 35 feet. Attachment 22324 Phone shot @ about 50mph. Attachment 22325 |
HMMMMM I am having ideasssss. I wonder about heat dissipation behind the dust cover though..... Our HHR gives little wiggle room back there and the fans on these units look bulky as well as the added/required resistor due to our wonderful CANBUS system.
Another reason I like the webbed heat sink, more flexibility. They get warm, but not hot to the touch. Bend the mesh out of the way and keep on motoring. Been running mine for over a year now.
