Fluid Film anti corrosion rust proofing info
I have been using this product for years mainly on small areas of cars like door hinges wheel cylinder bleeder screws etc.
Recently I have been using the product on basically any area that I find that is rusted and do not have time to properly clean and repaint with por15 paint etc
This product is lanolin based and does not attack paint.
I have been using it on the inside of the door bottoms where the gym's like to rust and I have been happy with the product.
Here is some info compiled from other sites.
I have been buying this on ebay in the aerosol version great stuff and thought you all might be interested in this product
FLUID FILM FREQUENTLY ASKED QUESTIONS If I spray Fluid FilmŽ on a painted surface, will it harm the paint?
Fluid FilmŽ will not harm paint. It can be sprayed directly on painted surfaces without any harmful effects. Will Fluid FilmŽ adversely affect plastic or rubber?
No, Fluid FilmŽ has no adverse effects on plastics or synthetic rubber. On 100% natural rubber, some swelling can occur. Can I paint over a surface treated with Fluid FilmŽ?
Because Fluid FilmŽ leaves a wet, non-drying film and imbeds itself in the pores of the metal, any surface treated with Fluid FilmŽ should be wiped down with a good biodegradable cleaner before painting. Will Fluid FilmŽ remove rust?
Fluid FilmŽ is not formulated to remove rust. However, if applied over existing rust, it will stop it immediately from spreading further. Fluid FilmŽ will penetrate rust and rust scale to the base metal, loosening and easing in the removal process. Will Fluid FilmŽ work on battery terminals?
Fluid FilmŽ is an excellent way to protect battery terminals. Because Fluid FilmŽ is non-conductive, make your connections before applying. The non-drying characteristics of Fluid FilmŽ will provide long term protection in this application. Does Fluid FilmŽ attract dirt?
Because Fluid FilmŽ remains wet, it will get an initial dusting upon application, but because it contains no solvents and will not become sticky, it will not gum up or create a build up of dirt. Is Fluid FilmŽ Biodegradable?
No, Fluid FilmŽ is not biodegradable. Will Fluid FilmŽ harm electrical connections?
No. Fluid FilmŽ is non-conductive and will not harm electrical connections. Make sure that all connections are made before applying Fluid FilmŽ. Will Fluid FilmŽ work in locks?
Fluid FilmŽ works very well in locks. Fluid FilmŽ will provide long term lubrication in a lock assembly. In cold weather applications, Fluid FilmŽ will keep locks from freezing, and since Fluid FilmŽ contains no solvent, it will not get gummy or create a build-up of dirt. Do not over-apply; a light application is all that is necessary. I've heard that Fluid FilmŽ will condition my work boots? Is that true?
Fluid FilmŽ is an excellent leather conditioner, and will soften and weather proof leather work boots. How is Fluid FilmŽ on snow equipment?
Fluid FilmŽ will prevent snow from sticking to snow blowers, snow shovels, snow mobiles, etc. and will also keep locks from freezing. It works in sub-zero weather conditions. Application may be required before each use. How does Fluid FilmŽ work on Motorcycle chains?
Fluid FilmŽ is an all purpose chain lube due to its non-solvent application. Spray Fluid FilmŽ directly on the chain, wiping off excess with a clean rag. Fluid FilmŽ will migrate into all areas, providing long-lasting lubrication and protection from rust. Great on bicycle chains as well. Can I use Fluid FilmŽ on firearms?
Yes. Apply Fluid FilmŽ to a clean dry rag, rubbing into metal surface as would be done with a polish or a wax. Will not leave fingerprints or affect bluing. The lanolin base of Fluid FilmŽ will also act as a conditioner on wood stock. Fluid FilmŽ will hold up in extreme conditions. I have a gallon of Fluid FilmŽ and want to thin it down. How can I do that?
The first recommendation is to thoroughly mix the product. Fluid FilmŽ is thixotropic, and will get heavier upon sitting. Achieving room temperature with the product will help as well. If a thinner version is wanted, start by mixing a small amount of lightweight motor oil to the product until the desired consistency is reached. Does Fluid FilmŽ dry out?
No. Fluid FilmŽ is a lanolin based product containing no solvents. It will not evaporate or dry from the surface. Fluid FilmŽ will leave a wet, non-drying film, that will provide long term corrosion protection on all metals and superior lubrication for all moving parts. Will Fluid FilmŽ stop grass from sticking to my lawnmower?
Wet grass will stick to almost any surface. Applying Fluid FilmŽ will prevent any corrosion from occurring and ease in removal of grass build up. Does Fluid FilmŽ protect all metals?
Fluid FilmŽ will protect all metals from oxidation and atmospheric corrosion, including steel, copper, lead, tin and zinc. It will stop chrome and brass from pitting and aluminum and magnesium from oxidizing. Can you use a pump type sprayer to spray Fluid FilmŽ in the bulk form?
No. Fluid FilmŽ needs to be sprayed at 60-80 psi. For larger applications, standard airless paint spraying equipment is required. What makes Fluid FilmŽ different from the competition?
Where most products contain between seventy and ninety percent solvent, Fluid FilmŽ contains none except for its propellant, meaning long lasting lubrication and protection. With no solvent, Fluid FilmŽ won't evaporate or become sticky or gummy, allowing it to migrate to other areas for lubrication or protection. With its unique lanolin base, Fluid FilmŽ will actually imbed itself in the pores of metal, resisting wash off and keeping moisture and oxygen from getting to the base metal. Containing no solvent content, Fluid FilmŽ lends itself to numerous applications where the comparative solvent-based products would not even be considered. What is the bulk flash point of Fluid FilmŽ NAS?
The bulk flash point of Fluid FilmŽ NAS is 405 F. Will Fluid FilmŽ burn greenery when applied to trimming or cutting devices?
No. Fluid FilmŽ will not burn greenery. What is the Shelf life of Fluid FilmŽ?
The Shelf life of Fluid FilmŽ is indefinite. In its aerosol form, Fluid FilmŽ is guaranteed for one year from the date of purchase. Has there been any outside testing conducted to show the effectiveness of Fluid FilmŽ?
Yes. The Department of the Navy conducted testing on maintenance products for Navy vessels and Fluid FilmŽ was found to provide superior performance. In fact, according to the Naval Surface Warfare Center, Carderock Division, Philadelphia, PA where material testing took place, the difference in performance...profound...most telling result of all the testing accomplished for this project." The Naval Ammunition Depot in Pensacola Florida conducted tests to find safer products for corrosion preventatives, and Fluid FilmŽ was found to supply superior protection in salt water environments. Furthermore, the test results found "outstanding results" in direct exposure to the outside environment, and concluded with these findings: "The results of the tests preformed indicate a superiority in Fluid FilmŽ for long term corrosion protection. The properties of Fluid FilmŽ help to achieve a more environmentally safe work place." Testing was also done in an outside testing facility according to Salt Spray resistance - ASTM B117 standards where Fluid FilmŽ was tested against WD-40, CRC 3-36, Corrosion X and LPS-3. After 3 weeks exposure Fluid FilmŽ had a total surface corrosion of 1%, while the closest competitor contained 40% surface corrosion. Two of the other competitors had achieved 100% surface corrosion during this same period, proving once again the superior quality of Fluid Film
Interesting. I have a can sitting on the shelf for years now, but had tried it out on battery posts, and for some reason didn't like it. I'll have to take another look at it. Sounds like it might be handy for the rust-proofing usage - especially on the motorcycle frames and on the inside of the doors of the cars.
thanks for posting that.
I have used Fluid Film for many years in the Marine Business in salt water conditions for corrosion control.
A little messy but works good. You just have to be knowlegable on how and where to use it.
Another great product I have used for light lubing and loosening stuck parts is Tri-Flow with teflon in a spray can. It has saved the day for me many times over.
It Beats WD-40 all to H_LL.
I only use WD for disolving road tar and the like.
SF
SF
