Front bumper bug repellant
"Crush Wrap"
http://www.collisionservices.com/Sho...ookieSupport=1
That's what I'm going to use when I take my Trans Am to the TA Nationals
Finally got the bra installed. The carbon fiber detail looks really nice in the sun. Install was a breeze. Had to drill 4 holes in some plastic pieces. Other than that, it fit like a glove. Here are some images of it.
Sweet, you can send that to me when you get back from the trip!!
If you have any chips Dr. ColorChip.com is the stuff, it is easy and works very well. Have a safe trip, does that fancy nose cover increase the boost a little ?
btw. where is the protection for the intercooler ? Flying chunks bend fins.
If you have any chips Dr. ColorChip.com is the stuff, it is easy and works very well. Have a safe trip, does that fancy nose cover increase the boost a little ?btw. where is the protection for the intercooler ? Flying chunks bend fins.
When I put the ZZP intercooler in I took out the lower grill. I like the looks with it out...driven with it like this for a couple thousand miles. When I do find a bent fin will probly b when the grill goes back in.
Good Luck with that !!! just a bent fin would be the least that could happen..
Good point Sleeper, what if the projectile was bigger than a bug ?? Like a box end wrench, that fell off someones bumper, when they forgot they set it there ?? You can still see that pretty new intercooler through the grill.
NEXTIMAGE
11
Dec 24, 2009 10:33 PM
