Help with DRL mod..
Old Apr 4, 2011 | 02:07 AM
trucky's Avatar
Exclamation Help with DRL mod..
Does anyone have a wiring diagram showing how the DRLs work in our cars? I am doing an FX-R projector retrofit soon and I want to mod the headlight using LEDs as DRLs instead of the actual HID bulb.
Old Apr 5, 2011 | 01:36 AM
trucky's Avatar
no one...? i know there is a fuse and relay, but i don't want to take apart the fuse box until i know exactly how the wires are run thru.
Old Apr 5, 2011 | 09:48 AM
Rainman's Avatar
Go to your local dealer, they'll be able to print out the diagram you need.
Old Apr 5, 2011 | 06:54 PM
Double0's Avatar
Are you wanting to add light or take it away.
Old Apr 6, 2011 | 08:31 AM
Putter's Avatar
If I read that right...I think he wants to re-route the DRL voltage to power some LEDs INSTEAD of the normal low-beam bulb (saving his HID builb)...but still have the low-beam work as designed when the actual headlights are on to power his HIDs.
Old Apr 7, 2011 | 01:37 AM
trucky's Avatar
EXACTLY! Like Putter said, I want to re-route the DRL wires to run some accent LEDs in my upcoming project.
And i will try to stop by the dealer to see if they will do that for me.
Old May 17, 2011 | 04:40 PM
Double0's Avatar
I tapped into run roof power for my DRLs and I used corner light power
