Help with mud flaps/splash guards...
Ok, I realize that this is supposed to be an easy install, but I have a coupe of questions.
1) Which side forward? There is a finished side and a smooth side, I would assume that the smooth side is towards the back, but since I didn't get the ones with the logo on 'em, I'm not exactly sure.
2) Did you have to cut a significant amout off the back set? I got part #12497400 which are plain black generic splash guards from GM. It does say that you might have to "trim some if necessary" in an area, but it seems like I would be cutting a third off of the back pair. I'm wondering if I got a set that aren't really made for the HHR.
Thanks for your help. I'm going to put off putting these on till I get some responses.
I went to http://gmpartsdirect.com/ and put in that p/n they did show a picture but don't know if it will help. Those Flaps certainly are made to fit a lot of gm cars as listed on that page.
The picture at your site is better than the one at the other dealer I posted. It would seem to show the finished side to the rear, which makes sense, but they seem to fit better the other way, but that seemed backwards. I guess there is some trimming to be done, but it seemed like a lot.
