How to Install Running boards
Hello I am new to this forum and have a question for all you guys and gals out there. I recently purchased a 2006 HHR LT Sunburst Orange, without the running boards on it. After reading posts on here ive decided to order running boards and install them myself (dealer wants like 250 to instal..Too much for me:cussing:). So I would like to know if anyone has installed these on there HHR's them selves and had any tips or instructions to help me out on this project. Any Help in this matter is greatly apreciated.:D
welcome!
SEARCH is your best friend on this forum. https://www.chevyhhr.net/forums/how-tutorial-library-21/installing-running-boards-1138/ The instructions included with the rb's are fairly straightforward. After reading the instructions and you still have questions dont hesitate to post them here. |
OK just got my Runningboards in and trying to install them, anyone know how to get the rocker panels off?? HELP!!:red:
Did you read the link I provided for you above? It tells you what needs to be done to remove the panels.
https://www.chevyhhr.net/forums/show...?t=1138&page=2 |
Probably pull hard. My HHR came with the running boards installed so I'm not 100% sure but I believe the rocker panels are held in by just clips.
Not that I did mine (dealer did it aftermarket, and after complaints), but there is one screw in each wheel well that goes into the rocker panel end, and then some clips. When installing the baords, make sure that the end of the board slides under the wheel well lining before attaching. And use the previously shown links for assistance! :thumb:
Yes I read the reply but I wasnt sure if there were any hidden srews cause this thing is really on there and even tho im replacing them i dont want to break them.
you will have a hard time saving the chips. Trust me, I tried and ended up tearing a couple off and throwing the rocker panels away.
well thanks for the help, Im gonna get started AGAIN, in the morning when theres more light, il post some pics when I get it done.:thumb:
