How to remove the Front Grille Bowtie Surround
How to remove the Front Grille Bowtie Surround. I can get the Bowtie itself off with no problem. My question is how do you remove the chrome surround off the Grille itself.
Here's a link to illistrate what I'm trying to accomplish: http://imageshack.us/photo/my-images/826/2u7.png/ Many thanks in advance |
Since you used one of my pictures (the bottom part is from this thread), I feel obligated to reply.
If I understand the question correctly, the suround, as you call it, is molded into the grille plastic. To remove it, you would need to cut it out and custom form a replacement section. |
Thanks Dracos for your time,
The area I want to separate is the chrome piece that surround the Bowtie. It appears to be a separate area. There are two small pins in the back. Here's a picture of another members grill that clearly shows what I would like to do.l The object is to re purpose in a similar manner as the picture shows. Here's a link: http://imageshack.us/photo/my-images/818/9yz.png/ Thanks again |
Now I'm fairly certain I don't understand what you're asking, the pictures don't match the question. That pic is a "no bar" grille, where the bars have been cut out of the grille surround. That one has gutter guard as a mesh, to which the bowtie is mounted.
The grille is actually chrome plating over plastic. In my pic that you used, the grille has been de-chromed. That process is covered in detail in the thread I linked. The plastic is gray; the yellow circle in the bowtie area is the epoxy I used as filler (which is also visible where the ends of the upper and lower bars used to be). |
Hey Dracos,
I apologize for the confusion. I kept on researching this and found the answer on Ebay. Here's a picture of the Emblem Assy. http://imageshack.us/photo/my-images/607/6fz.png/ There it is as a separate piece which is mounted with 3M tape. Now I know how to proceed. Thanks |
Yes, the entire badge is held on by 3M tape. Saw through it with fishing line, and have a bottle of Goof-Off ready to clean it up.
