lower grille
Old Aug 22, 2012 | 11:45 AM
skyline26's Avatar
lower grille
does anybody have some pics on how their lower grille hardware and set up looks? Mine came with 2 brackets with a bend on the ends and then a screw goes through the middle of them, but the thing is that it doesnt sit properly. It falls forward/slanted, doesnt sit flush with the opening
Old Aug 25, 2012 | 10:53 AM
skyline26's Avatar
Old Aug 25, 2012 | 11:23 AM
American & Proud's Avatar
Rest In Peace
The lip on the bracket catches the inside lip of the bumper and you tighten it down until its where you want it sitting and it's tight in place.
If it still is loose just bend the brackets so it will tighten sooner.
Old pic from when I installed mine.
It sits just inside the outter edge on mine.
Old Aug 25, 2012 | 05:39 PM
skyline26's Avatar
would you be able to take a pic of the backing? when i tighten it, thats when it starts to slant and looks bad, brackets dont seem like they fit right down there..and if i dont tighten the brackets it looks good but then its sooo loose
Old Sep 1, 2012 | 11:11 AM
Jesse t55's Avatar
American & Proud....Where did you get your grill , looks awsome ...Did you have to cut and fit in stock grill....
Old Sep 1, 2012 | 01:45 PM
jay loukakis's Avatar
Mine worked a little loose so I used blue Loctite.
Old Sep 1, 2012 | 01:50 PM
skyline26's Avatar
its not the fact that it comes loose, it just doesnt seem to fit in the lower opening with the brackets on properly. hard to describe, ill take pictures of it tomorrow and maybe it will clear it up
Lethal Tendencies
Mar 17, 2015 11:16 AM
tracy waddell
South Pacific
11
Jun 23, 2010 02:27 AM
SD70M2
7
Jan 13, 2010 12:05 AM
Uma
South Pacific
22
May 2, 2008 10:19 PM
