Musical Horn install?
Old Jul 31, 2007 | 08:27 PM
Wheelie7's Avatar
Hi!, I just ordered a musical horn Jukebox put install on Wheelie and would like to know where is the best location to install it?
Thanks!
Old Jul 31, 2007 | 09:23 PM
ymerej_mortsdnil's Avatar
Thumbs up Very Cool!
I'm sorry I don't know much about installing such a device, but you should definitely post links to sound clips of it after you get it installed!!!
Old Jul 31, 2007 | 09:31 PM
Wheelie7's Avatar
I Plan on it!!, I cant wait to get it and put it on, I've wanted the CHARGE! tune on my HHR for a long time, I am starting on doing some mods which include putting racelike decals on it and a big 7 on my doors (front ones). I CAN'T WAIT!!
Old Aug 1, 2007 | 06:55 AM
Dan's HHR's Avatar
Thanks!
UNDER THE HOOD
Old Aug 1, 2007 | 07:56 AM
kdugg_fl's Avatar
Check with mitzkitty and karen1953, both have installed aftermarket horns. I think mitzkitty has the same one you bought. Maybe we could have a g2g and help you out. :)
Old Aug 1, 2007 | 08:11 AM
Wheelie7's Avatar
Originally Posted by Dan's HHR
UNDER THE HOOD
HAHAAHAA Dan, Very funny, LOL!, be careful, don'talugh too hard or you will wee wee all over yourself..LOL!
Old Aug 1, 2007 | 08:13 AM
Wheelie7's Avatar
Thanks KD, I am kind of timid when it comes to installations that have wiring harnesses.....I might mess things up and blow Wheelie up in the process, and I don't want to do that! LOL, I'll ask them, If I can find them! =)
Old Aug 1, 2007 | 12:18 PM
catzcradle's Avatar
Well, I can only tell you what I did. For the control module, I dremeled out a small hole in the center covered cubby and dropped a power and ground wire down to the fuse box tapping into a switched cable and a bolt for ground that is left of the fuse panel. I then used split loom on the wires so the keypad can be pulled out of the cubby and used from the seated position. I then extended the speaker wire that came from the horn itself, and routed that through the rubber grommet in the firewall on drivers side using a coat-hanger. There is another thread on how to get that wire through from another member. The horn itself I was able to mount above the radiator on the drivers side to an existing bolt-hole, but it can also be mounted lower in the facia, or any other open spot under the hood. I can get some pictures this evening if you want.
This is for Mitzkity's car.
Old Aug 1, 2007 | 12:20 PM
mitzkity's Avatar
OH OH - I found you folks some sound bites...
http://www.realtruck.com/productline..._keyboard.html
Old Aug 1, 2007 | 01:04 PM
solman98's Avatar
I just looked at the link that mitzkitty provided. Is that what you bought? Or did you buy a set of musical air horns? If you bought the electric, you can put that horn anyplace.
If you bought a nice set of musical air horns, point them to the ground.
