Mods - Interior Discussion related to the looks of the interior of the HHR.
LED Interior lighting
Old Mar 22, 2012 | 10:03 PM
havoc3d's Avatar
I'm thinking I'd like to do some under dash and maybe under seat interior lighting that is on with the rear cargo dome light.
Anyone know where that bugger runs? I have some network discovery equipment that might work if I pull the fuse and plug it into the wires...but I figured this is the type of thing 4/5 of the people here already know
Old Mar 22, 2012 | 10:30 PM
LawDog88's Avatar
Pretty sure you could tap into the dome light at the top.. then all you'd have to figure out is the front half..
Old Mar 23, 2012 | 10:05 AM
havoc3d's Avatar
Yeah, I could grab it at the ceiling light or the fuse box. I was just thinking if I could tap it somewhere around the dash, I'd save myself some disassembly and wiring.
Old Mar 24, 2012 | 01:28 AM
jeff schaffer's Avatar
ran off the doors & alarm.
I ran my off the doors worked easily and turns on when i open the door and goes off when i close the door or hit my alarm.
jeff
Old Mar 24, 2012 | 12:00 PM
bassbase's Avatar
I plugged into the diagnostic port under the dash and put in a round toggle switch on the waterfall to turn on and off. I put lights under the dash on both sides, under both front seats, 2 on each side of the cargo area and one in the sub box to light up the woofer.
Old Mar 24, 2012 | 12:12 PM
Breadfan's Avatar
I'd like to do this myself. I'm thinking switched under-dash/seat that is on when the car is on but can be switched off manually and cargo lights that come on with the dome light when the door or hatch is opened. If I'm studious and pull all the wiring to a labeled junction box, I can reconfigure from one spot.
Rayhawk456
Oct 30, 2013 05:39 PM
Digital_Rapture
Oct 16, 2008 04:43 PM
Rebel13
61
Apr 26, 2007 11:23 AM
buz1953
17
Feb 26, 2007 08:26 AM
lynnrock
Nov 21, 2006 05:55 PM
