Mods - Interior Discussion related to the looks of the interior of the HHR.
Rear view mirror down grade
Old Jan 3, 2023 | 06:22 PM
peterdulux's Avatar
I have an 08 with the onstar, self dimming and compass rear view mirror. Many of you know how small and dim the map lights are and they can't be changed.
I went to a wrecker today and got a mirror from a different year that has the much larger lights but no other accessories built in.
I would prefer more light than whissels and bells so would like to swap them. the mirror without the accessories has a single plug with 3 wires as apposed to the 08 with a much larger plug with 8 wires.
Is it possible to do this swap and redo the wiring so the lights work and not cause any faults or codes?
Old Jan 3, 2023 | 06:48 PM
Yes, did you get the 3 pin harness from the older model year?
Older mirror has 3 wires Blue with white stripe, grey, and black
Old Jan 3, 2023 | 07:26 PM
peterdulux's Avatar
Yes I did get the 3 pin harness, got about 10 inches of wire.
Old Jan 3, 2023 | 07:36 PM
peterdulux's Avatar
Old Jan 4, 2023 | 06:58 AM
Some of the wires are live , so disconnect the negative terminal at the battery. Then you the splice the 3 wire connector , into the 3 wires matching colours and then tuck the other up over the head liner
Use this style connector to splice
pdmorris1
Mods - Interior
42
Apr 12, 2016 09:32 PM
FLORIDA
Oct 28, 2010 03:54 PM
checkob
Dec 14, 2009 11:39 AM
Old Lar
Jan 31, 2009 07:42 AM
plakman
Oct 27, 2007 02:48 PM
