Seat attachment
How are the front seat attached to the floorpan on our SS's? I see bolts in the back, but what about the front? I'd like to raise the front or lower the rear to get a bit more thigh support..............
After you take out the two rear bolts, you slide the seat assembly back to unhook the front mounting.
Originally Posted by Vcode455
(Post 561187)
https://www.chevyhhr.net/forums/how-tutorial-library-21/seat-removal-carpet-install-13261/
Looks like it might be easier to put spacers under the front rather than trying to lower the rear. |
If you have access to a small mig welder, cut the bar at each end, weld a 1 to 2 inch plate onto the bar and re-weld the ends at the top giving you the desired "drop" in the back. If you mess it up, the just yards are full of spares to replace it.
Originally Posted by ebritt
(Post 561275)
I do have a spare seat bar to experiment with. Junk yard bar-$20 Dealer price $86 |
