Mods - Interior Discussion related to the looks of the interior of the HHR.
Seat heaters
Old 12-16-2018, 11:23 AM
Technical Moderator
You have to look closely at that Amazon ad; there are 19 different options you see when you click on the picture thumbs.
Pretty simple to use the waterfall, either unused hole or drill/cut new.
Fuse #23 20A underhood fuse box.
donbrew is offline
Old 12-16-2018, 11:55 AM
edlafon's Avatar
Good point
My choice was for the 2 round switch, 13/16", two color illumination
Thank you for the fuse location reference
edlafon is offline
Old 12-16-2018, 12:26 PM
edlafon's Avatar
Is there a preferred location for going through the firewall?
edlafon is offline
Old 12-16-2018, 01:38 PM
Anywhere, there’s no wires, plumbing, heater core.
I reference a point in the engine side then double check from the dashboard side.
Oldblue is offline
Old 12-16-2018, 02:23 PM
Technical Moderator
Punch a hole in the grommet with a coat hanger.
donbrew is offline
Old 12-17-2018, 05:34 AM
Lethal Tendencies's Avatar
I plan on doing this mod after the new year. right now I am working on improving my stereo sound.
Lethal Tendencies is offline
Old 12-26-2019, 12:19 PM
Going to finally get around to installing seat heaters next week. Is fuse #23 a constant power source or is it activated by the ignition? Thanks
Old 12-26-2019, 02:09 PM
Technical Moderator
here is the wiring diagram
hseat.pdf
donbrew is offline
Old 12-27-2019, 03:13 PM
Attachment 47654
Cool thanks
Old 01-13-2020, 02:09 PM
Got mine installed over the weekend. Here is the kit I used
https://www.ebay.com/itm/4X-Car-Seat...53.m2749.l2649
Quick Reply: Seat heaters
