Tie into RAP
Hi Folks,
I want to add in some 12v outlets that function with RAP. I currently tied it into the existing outlets, but I want to have switched (powers GPS, etc.) Any insight as to what Circuit i should look into would be great. I noticed on the fuse diagram on the right of the waterfall there is a fuse marked RAP, but i'm not sure if that is where I would tie in. Thanks in advance! --John |
Noticed in another thread there might be something to tie into.
https://www.chevyhhr.net/forums/problems-service-repairs-42/problems-accessories-working-accessory-position-ignition-43866/ Not sure if this is the best solution. Anyone care to weigh in? |
https://www.chevyhhr.net/forums/showthread.php?t=43866 Not sure if this is the best solution. Anyone care to weigh in? |
There is one marked "spare" that functions under RAP, also the sunroof, power windows.
I used a dual fuse "add-a-circuit" adapter, crappy tire sells em. |
Thx prod. I'm going to pop by walmart and see if they have em, since they are open late. Otherwise i'll hit up CT tomorrow.
Thanks! |
