Mode colour viewing problems
Old May 15, 2023 | 09:35 AM
greg8453's Avatar
Originally Posted by donbrew
P0300 means "unidentified misfire detected" not whatever nonsense the reader "says". It won't light the CEL until the catalytic converter is in danger.
If you have air brakes you might want a oil/water separator, more Farcebook nonsense.
Coolant temp should never get below 180F, bad t-stat. Fan does not turn on until 219F then off when the temp gets to 180F.
Blow by is from rings. Lots of blue smoke from valve guides.
Any oddities with oil or water levels? Check the water under the pressure cap, not just the bottle.
Maybe use red font. In dark mode you can hardly read it.
Old May 15, 2023 | 11:33 AM
I can see Don’s post just fine.
Maybe you should get out of dark mode.
Old May 16, 2023 | 07:58 AM
The only red is in my sig.
Old May 16, 2023 | 08:47 AM
PulpFriction's Avatar
There are contrast problems in both modes but probably worse in dark mode. It is typically browser and even device dependent, because not all displays show the same colors. With my Android device, it's impossible to read the blue in the quotes and the user tags when in dark more. I highlight the quotes or scroll up to read them.
Old May 16, 2023 | 08:59 AM
This is not pertinent to the thread it was in please don’t hijack other members threads
Old May 16, 2023 | 09:36 AM
greg8453's Avatar
My point in using red is it is visible regardless of dark mode or not.
Old May 16, 2023 | 10:23 AM
Well I’m confused. If using red is the way to be visible, then why aren’t you typing in red ?
Old May 16, 2023 | 10:31 AM
greg8453's Avatar
Obviously I'm an idiot.
Old May 16, 2023 | 12:28 PM
OK, but how is that MY post, that was all default black is a problem? The only colors I normally use are in my sig.
Old May 16, 2023 | 02:33 PM
I'm in dark mode now, and I see what Greg is referring to. In the post by donbrew that Greg quoted, everything after "If you have air brakes you might want a"
E
