Plasti-Dip/Plasti-Dipping A sub-forum for the discussion of Plasti-Dip and its various uses.
Plasti Dipped HHR
Old Nov 10, 2012 | 05:59 PM
  #41
havoc3d's Avatar
I just did a two tone red/black on our company's xB. Thinking I'm going to do my SS in red this spring. Getting to cold for me to want to spend the time in the garage now.
I used the HVLP spayer on dipyourcar.com and their gallons. Thinking for red over my black I'll probably need 4 Gallons. 2 Gallons for the bottom half the xB turned out to not quite cover well enough.
Old Jan 16, 2013 | 11:27 AM
  #42
Double0's Avatar
Pics??
Old Sep 29, 2014 | 08:44 PM
  #43
Can anyone estimate how many cans it would take to Plasti-dip the four fenders, both running boards and both bumpers?
Thanks
Boydie
Originally Posted by Oldblue
some red and white pin stripes and wow hot rod retro!!
Old Sep 29, 2014 | 10:48 PM
  #44
lunchbox's Avatar
You will need quite a few, but i wouldn't suggest using the rattle cans for that much surface area. If at all possible, get the spray gun and a gallon of dip. The rattle cans are good for wheels, and each wheel usually takes one can, just as a reference for coverage. If you do decide to go for it, i would think about 8-10 should get the job done, with adequate layers ( you will regret spraying too thin when it comes to peeling it off later, i know this from experience ). Rattle cans can yield descent results with a little practice, i just prefer the gallons for an easier application. Have you checked Dip Your Car to see if there are any authorized dealers in your area?
Old Sep 30, 2014 | 09:19 AM
  #45
Thank you lunchbox. Not sure how I will proceed. I live in Northern Michigan, not close to any metropolitan areas. I painted cars for a hobby and the gallon and sprayer would be the way to go. I'll check Dip your car to see if any are close.
Boydie
Old Sep 30, 2014 | 10:52 AM
  #46
redridehhr's Avatar
+ 1 for Lunchbox. If you didn't put at least 4 coats, it will be a ***** to peel off. Sprayed the front of wife's car and it took everything the interstate(under construction 40 mi.) could throw at it.
mpysh
Oct 15, 2014 10:12 AM
Turbo Hearse
20
Aug 10, 2014 04:45 PM
1970judge
12
Jul 27, 2014 05:34 PM
843de
Jul 17, 2014 11:51 PM
capp002
Mods - Interior
11
Mar 29, 2012 05:53 PM
