06 HHR check charge system
Old Jul 21, 2018 | 09:17 AM
Ashley Givens Lee's Avatar
Okay so my car hasnt been used in a few months so when I went to turn it over it didnt do anything. I recharged the battery and put it back on now its in lock mode... did the 30 minute relearn but while doing it it says to check charge system and battery saver on... how do I check the charge system?
Old Jul 21, 2018 | 12:03 PM
Thread moved, since it is not a "how-to".
You should not have needed to do the relearn. The reason the security kicked in is because the battery went below 9 volts. After it gets fully charged you just need to use the correct key 2 times.
Evidently, your battery is not fully charged. It needs to be more than 12 volts.
You check the charging system by going to your local AutoZone/Advance/O'Reilly and asking them to check your electrical system.
Xcjumpman
Jul 17, 2016 02:07 PM
Smuffy
Jul 7, 2014 03:39 AM
Kitty1013
Nov 8, 2013 12:05 AM
R CA HHR
Apr 17, 2011 08:42 AM
