06 hhr temp not reading but a/c works
Old Apr 4, 2019 | 07:59 PM
  #31
The $15.00 one fails like the rest of them
the 131-158 doesn’t
Old Apr 4, 2019 | 08:03 PM
  #32
mika_navajas's Avatar
the 131-158 doesn’t
I got the 131-158 for $70 at a dealership. It was $150 market value. I’m in Puerto Rico, guess it’s more expensive here.
Old Apr 4, 2019 | 08:37 PM
  #33
Did you inspect it to see if it was broken? Did you inspect the temp sensor wires? Is there a P0128 code or just the AC doesn't work and raedout flat lined?
Old Apr 5, 2019 | 10:06 AM
  #34
I inspected it, seemed fine. AC works but always has. I have the P0128 code again twice. Says I need to replace the thermostat. It is only heating to about 160 but the first day it was at or above 180. Does the position of the thermostat mvake a difference? It fit in nicely with the bar on top positioned about 10 o’clock to 4 o’clock (looking into the hood towards the back of the car).
Old Apr 5, 2019 | 10:41 AM
  #35
No, the position of the thermostat in the housing makes no difference.
Old Apr 5, 2019 | 01:53 PM
  #36
It should get up to 180F in less than 5 minutes and stay above 180F. If it does not there re only a couple of things; t-stat stuck open, temp sensor error, air bubble in the coolant.
Usually some random piece of junk gets caught in the t-stat preventing it from closing. That is usually part of the rubber seal that is part of the t-stat, sometimes there is junk floating around in the coolant.
Old Apr 5, 2019 | 03:07 PM
  #37
Have you burped the cooling system ?
Old Apr 5, 2019 | 04:09 PM
  #38
Which speaks well for flushing the existing coolant and replacing it when replacing a failed thermostat.
Old Apr 5, 2019 | 05:14 PM
  #39
I like to remove the T stat housing and upper rad hose and back wash the block and then the rad.
Old Apr 5, 2019 | 05:59 PM
  #40
I burped it when I changed the thermostat. I will burp again. I have put new coolant in each time I changed the thermostat (2x now).
