07 2.2 manual - issues w reduced engine power, otherissues
Old Aug 1, 2019 | 06:05 PM
Roy73's Avatar
Started two days ago- engine went into reduced engine power mode then the low fuel and power steering warnings came on. Limped home- the car from a dead stop, left off clutch gave it gas and it started jerking and then finally smoothed put enough to get into 2nd
I pulled the fuse for the ECM and it worked for most of the day , but on the expressway home it didnthe reduced engine power and the other warnings. Have not pulled codes yet- any suggestions? Replace ECM?
Old Aug 1, 2019 | 06:53 PM
Replace the ECM? Why exactly do you think that will resolve the issues, or are you basing that just on spec?
Don't you think it might be a much better idea to download the codes and follow up with them first?
Old Aug 1, 2019 | 07:42 PM
Roy73's Avatar
Just some of the other things I’ve read online about ECM and how it might affect the limp mode. But you’re right- I need to pull codes
Old Aug 1, 2019 | 07:48 PM
At least have the battery and charging system checked before you start blaming those scary computers.
Do you mean you pulled fuse #41 underhood fuse box and the engine ran at all? Why would that even cross your mind?
Old Aug 1, 2019 | 08:04 PM
Roy73's Avatar
I pulled the 25 fuse from the inside to reset the ECM per another post I read. The car ran fine for the short trip to work and then on the way home it was back to the REP and then here we are.
Old Aug 1, 2019 | 09:21 PM
What that did was clear the codes that were causing the malfunction. As soon as the OBD2 tests run and fail the action of the computer returns. Fix whatever caused the code fix the problem; don't blame the messenger!
Old Aug 1, 2019 | 09:23 PM
Roy73's Avatar
Yeah I figured that was the case so I’m taking it on for a diagnosis on the morning.
Old Aug 2, 2019 | 09:08 AM
A simple post of those codes like P0010 or P0128 , the parts palace near you should have code reader services.
donbrew
0
Mar 22, 2016 08:10 AM
desmonda
Dec 24, 2014 07:43 AM
chevhhrdummy
Sep 30, 2014 07:48 PM
ahuschka
Aug 25, 2013 07:22 PM
menance
Dec 22, 2010 06:14 PM
