07 Chevy HHR won't crank not even A click.
Old Feb 28, 2025 | 07:00 PM
Kyle Tay's Avatar
Old Feb 28, 2025 | 07:19 PM
Hi Kyle, to the forums!
Have the ignition related recalls been performed? Link in my signature to check.
condition of the battery? Does anything else work (or not work)?
Old Feb 28, 2025 | 10:19 PM
Any other clues?
Old Mar 1, 2025 | 04:00 AM
Kyle Tay's Avatar
HHr won't crank.
New starter alternator 12.28 at remote. post 12.28 at starter Everything working called dealer reacal fix has been done was starting then no crank it will go days or weeks starting fine sometimes stalls then restarts sometimes it won't can ark starter with screwdriver and will start but sometimes a battery and jumper cables on starter make it start it snapps out of not starting until the next no crank happens again
Old Mar 1, 2025 | 08:50 AM
12.28 is a dead battery, should be 12.6-12.7. New starter and alternator before or after this started? Why were they replaced? Have you tried tightening the 4 bolts in the under hood fuse box? Have you checked for continuity between the starter and alternator? Checked for voltage at the starter? Checked for voltage at the alternator? Checked battery connections?
Old Mar 1, 2025 | 10:15 AM
Kyle Tay's Avatar
HHr won't crank
The problem started before new starter and alternator voltage at starter 12.27 could be fuse box moved it back to check ground wires behind fuse box and it went back to no crank.
Old Mar 1, 2025 | 11:42 AM
Kyle Tay's Avatar
HHr won't crank
Originally Posted by donbrew
Any other clues?
Dash lights go on starter and alternator put in after problem started alternator was bad starter was good
​​​arted
Old Mar 1, 2025 | 11:46 AM
No need to start a new thread, I've merged them now.
Bad alternator may have killed your battery. Or the bad battery killed the alternator. Either way, the battery is Dead or damaged.
Old Mar 1, 2025 | 11:57 AM
If you “ moved” the fuse box, you need to recheck your connections there. AND, make sure all the fuse and relays are well seated.
Lastly. Tighten up the inner fuse box bolts. Really tight or as Donbrew says Gorilla tight. Lose fuse box bolts have been a known HHR problem.
Old Mar 1, 2025 | 12:27 PM
There should be 2 large red wires connected to the front lug on the fuse box and 1 smaller wire on the lug closest to the firewall.
The best way to check the bolts is to loosen them, then retighten very tightly (past afraid to strip them). If you removed it you need to hear and feel clicks.
There is no ground wire behind the fuse box. The lug closest to the firewall is power for the power steering.
Check the voltage at the alternator. Some have a fusible link between the starter and alternator (that would show as a bad alternator).
