07 HHR hard start
Old Sep 21, 2019 | 07:18 PM
trevgillette@gmail.com's Avatar
07 HHR hard start
My car started hard starting last night. Check engine light came on and got codes around the O2 sensor. It previously had a code on a misfire cylinder, so I bought new plugs and coils and installed them today. Check engine light went away but the hard start is still happening. Turn the key, it cranks and stalks out. Turn the key again and it fires up. It smells like it’s running rich as well because I’m detecting an exhaust smell.
could this be an issue with the fuel pump or filter? It’s not pulling any codes for fuel pressure. Any help in the matter is appreciated.
Old Sep 21, 2019 | 07:32 PM
Welcome to the site, please post the actual codes .
Engine , year, mileage transmission
Old Sep 22, 2019 | 01:13 AM
ie: what was the code for the O2 sensor, as well as the one regarding the misfire.
Swapping plugs and coils between the cylinders might have been a much better (and cheaper) diagnostic technique
Old Sep 22, 2019 | 08:28 AM
Cat Man HHR's Avatar
Always do this when asking a problem.
Old Sep 22, 2019 | 09:27 AM
code P1811 and code p1133. 07 hhr, 258000 miles. 2.2 engine. The plugs and coils had never been changed which is why I invested in parts to do that. It cleared the check engine light, but still hard starting and smells like it’s running very rich on the fuel because I’m smelling exhaust in the cabin. I’m going to take it to have codes checked again later today to see if anything else is there.
Old Sep 22, 2019 | 09:34 AM
https://www.transmissionrepaircostguide.com/p1811/
check the MAF sensor, and clean it.
https://ericthecarguy.com/kunena/8-S...ine-code-p1133
O2 sensor
check the flex pipe for cracks also, that will cause fuel orders in the cabin, so will a corroded fuel vapour line
Old Sep 22, 2019 | 09:35 AM
1st thing to check would be the flex joint on the exhaust. That's a known weak spot, prone to failure. It's located at the exhaust manifold and connects the manifold to the exhaust.
If it is cracked, then it's most likely the cause of the O2 sensor codes.
ImNewHere
Nov 22, 2016 08:36 PM
MCT
Nov 11, 2011 02:45 PM
fairaljr
Aug 17, 2011 04:30 PM
kmcrae476
Aug 4, 2011 07:51 AM
salussj
Aug 26, 2010 03:42 PM
