07 rear wiring harness - passenger side
Old Mar 24, 2023 | 04:44 PM
bwiencek's Avatar
Hello - daughter bought an 07 HHR LT, 2.2L automatic and there is a burnt piece of wiring harness that is hanging down at the rear of the engine and towards the the passenger's side - it looks to have been burnt on the exhaust and is now hanging down. Any idea of what that wiring goes to and where the other end might be so I can splice it back together?
I believe it to be this part of the harness (found this pic from the forum when searching and circled what I think it is)
Any chance it's the rear O2 sensor as we've got a code P0420 catalyst below efficiency that could possibly be no downstream O2 sensor (haven't logged live data to see if it's working yet) - going to dig into it tomorrow afternoon but thought I might see if anyone knows where those wires go to.
Old Mar 24, 2023 | 04:48 PM
greg8453's Avatar
I would follow that burnt wire and see where it goes. We can only guess. My initial thought was an O2 sensor.
Old Mar 24, 2023 | 04:59 PM
bwiencek's Avatar
It's hanging down loose - quick look didn't see where the loose end should go...
Old Mar 24, 2023 | 05:40 PM
That wire goes down past the water pump, behind the engine to the speed sensor on the transmission
P0420 is usually related to a clogged catalytic converter.
Old Mar 24, 2023 | 09:44 PM
P0420 proves there is a #2 O2 sensor, that is working, telling you the cat is dead. If the O2 sensor had a problem it would throw a code.
If it is hanging there, the other end must be hanging too. What doesn't work? A broken cable must go somewhere.
I hope the car was really cheap and she has a lot of money budgeted to fix it.
Old Mar 24, 2023 | 09:57 PM
greg8453's Avatar
My question is why did the harness get burnt. Has there been work done? They are secured away from heat but sometimes guys fail to secure them after a repair.
Old Mar 24, 2023 | 10:57 PM
What you've circled is on the passenger side, as Oldblue noted. No oxygen sensors over there.
NightmareHHR
Jun 30, 2022 05:01 PM
gamma-wes
Jun 25, 2014 07:56 AM
Lee3333
"How To" Tutorial Library
Mar 9, 2014 04:38 PM
ICUFOS
Sep 1, 2009 02:16 PM
Scrivs
Jan 15, 2009 01:39 PM
