0U100 no power to fuses #41 #42#45 on a 07 hhr . No crank
Old Mar 7, 2026 | 12:44 PM
If it came on for a short time double check for bent pins in the connectors and double check the ground wire connections. Some times a wire gets missed but I’m sure you’ll find it.
Old Mar 7, 2026 | 02:40 PM
No communication is because no power to the ECM.
I would suspect either the relay or the PNP switch. Something is inhibiting the ground signal from the ECM.
I doubt it is the ECM itself. Has the key recall been done?
Old Mar 8, 2026 | 11:44 AM
Mlamey01's Avatar
2 key recall stickers , and the other ecm with no extra ground read all info on scanner.the original scanner was dead .and everything came on for a second after installing different ecm . So how can one ecm not read anything and once read everything with nothing changed?
FuriousSon
Nov 3, 2022 11:14 AM
Allen P
May 25, 2021 04:10 PM
Slyk221
Mar 25, 2021 06:58 AM
Roy73
Aug 2, 2019 09:08 AM
rendon47
Dec 26, 2013 07:00 PM
