2006 2.2 Automatic P0340
Old Oct 3, 2018 | 11:18 AM
RatRodS's Avatar
I have the code P0340, I have checked a few threads here and what was recommended is replacing the coil packs and ignition module. Just wondering if this is the correct part https://www.rockauto.com/en/catalog/...tion+coil,7060 thank you
Old Oct 3, 2018 | 11:43 AM
That does say it is the coil pack for a 2006 2.2L. I'm not sure I would go with the $17 one.
That is the most common reason, but there are others. Just a warning that it might not fix it.
Make sure all the connectors are in good condition and no broken/frayed wires.
Old Oct 3, 2018 | 12:10 PM
RatRodS's Avatar
Thank you, it was in the shop that my brother in law runs and they checked out quite a bit and recommended these parts. I ordered the NGK part.
Old Oct 3, 2018 | 06:39 PM
P0340 or P0304??? P0340 refers to a problem with the Camshaft Position Sensor.
Old Oct 3, 2018 | 09:48 PM
2006 does not use cam sensors. The position of the cam is calculated based on data from the ICM.
If you understand the way Harley-Davidson handles the spark, it is much the same. 2 plugs fire each cycle,
Old Oct 4, 2018 | 10:03 AM
Ahhh cool. Thanks for the info Don - at least the coil packs aren't expensive.
Old Oct 4, 2018 | 07:36 PM
No, you're right Whopper. This is a valid question. The OP has been on site since you asked it, but did not answer.
Old Oct 8, 2018 | 10:39 AM
RatRodS's Avatar
Sorry, just checked and it is P0340. The new coil pack arrived and will be installed this evening.
Old Oct 12, 2018 | 07:20 AM
RatRodS's Avatar
Update: new coil pack, spark plugs and air filter installed. Drove it for a couple of days and no codes. Fast shipping from Rock Auto.
Old Oct 12, 2018 | 09:02 AM
Please keep us updated on this issue.
