2008 2lt - sun roof access
Old Dec 13, 2012 | 02:19 PM
rdjohnston50's Avatar
My sun roof won't retract but will lift to vent position. Something is jambed in there. Anybody accessed the sunroof yet? I am assuming I have to remove the entire headliner. Am I correct in this assumption?
Old Dec 13, 2012 | 07:01 PM
ChevyMgr's Avatar
You will need to at least drop it down. It may require replacing the entire assembly since there are very few serviceable parts, unless you do find a foreign object jammed in a track.
Old Dec 14, 2012 | 11:52 AM
sun roof
Thanks, I appreciate the info. Is the assembly something I could find used?
Old Dec 14, 2012 | 12:31 PM
My first question is do you hear the motor trying to retract the sunroof? If not, then it could be as simple as a bad control switch.
Never hurts to try the easy things first.
Dutchman09
Jun 25, 2010 05:27 PM
CavittyCreep
May 19, 2010 06:30 AM
chrissgee
Dec 7, 2008 10:32 AM
finatics
May 15, 2008 06:44 PM
PerryHallHHR
Aug 21, 2006 11:37 PM
